Steering wheel boss?? Which one?
Postby spondootre » Mon Jan 23, 2006 7:19 pm
I'll ask the ebay guy if he has a transit one then as that's more likely to give me the same steering wheel position if the capri is a shorter boss. Then i'll have to find a decent steering wheel!! will a mountney boss fit with all 6 hole wheel then? like say this one :
http://cgi.ebay.co.uk/FUTURIST-metalic- ... dZViewItem
It says at the bottom that it fits a momo, does that mean it will fit a mountney?!?! (Steering wheels are another mystery to me incase you hadn't noticed!)
spondootre
Postby Luke » Mon Jan 23, 2006 7:22 pm
spondootre wrote:It says at the bottom that it fits a momo, does that mean it will fit a mountney?!?! (Steering wheels are another mystery to me incase you hadn't noticed!)
No momo is different to mountney!
astrali is the same as mountney!! but you can get adapters!!
:D
Postby spondootre » Mon Jan 23, 2006 7:25 pm
So I can get an adapter for this wheel if I wanted? any idea where I could get one? I looked on fleabay but can't spot any......
Cheers
Malc
spondootre
Postby WINDSCREENGUY » Mon Jan 23, 2006 7:36 pm
right the transit boss is the short stubby one which might sit your steering wheel too close to the indicators.
the capri is longer and is what i used on my smiley face as when fitted with a mountey steering wheel gave roughly the same distance from the indicator arm as the stock steering wheel .
my new one is momo. momo has a smaller diamater and the screws are alot closer together ,the mountey is much larger in diameter and screws are spaced further apart
for that steering wheel you will need a momo boss and they are £30 from watford classic cars
formally grey van man.
2010 115 semi high mwb . Fully loaded.
WINDSCREENGUY
previously grey van man
Postby spondootre » Mon Jan 23, 2006 8:25 pm
right so to get this wheel to fit I need a momo Capri boss to give me the right length. I'll ring them tomorrow cos I can't find any momo ones on the ebay list only mountney.
spondootre
Postby spondootre » Mon Jan 23, 2006 8:28 pm
right now i'm confused!! what's going on with this one because it says it fits momo or mountney??
http://cgi.ebay.co.uk/BLUE-BLACK-LEATHE ... dZViewItem
spondootre
Postby WINDSCREENGUY » Mon Jan 23, 2006 8:29 pm
that is if you have a steering wheel with the same depth as a smiley one yes. watford classic car had to order me one in it took 2 weeks
WINDSCREENGUY
Postby Luke » Mon Jan 23, 2006 8:31 pm
spondootre wrote:right now i'm confused!! what's going on with this one because it says it fits momo or mountney??
bad description that one!! i'd guess he's wrong :? looks like a momo size boss to me!!! :D
Postby WINDSCREENGUY » Mon Jan 23, 2006 8:36 pm
and me
WINDSCREENGUY
Postby spondootre » Mon Jan 23, 2006 8:38 pm
I'll also ask for a length on the 2 bosses then!! and compare that to what's on there now and that should get me a rough idea.....
glad that is just a rubbish description!! I've had a quick comparison of momo - mountney on ebay and there is quite a difference in the position of the holes so should be quite easy to tell apart.
Thanks guys
Cheers
Malc
spondootre
Postby Valsheda » Mon Jan 23, 2006 8:46 pm
Good luck Malc , keep posting on this thread with your progress as i am thinking of changing my wheel , so any info is greatfully accepted :D
Valsheda
Top Tourneo Owner
Postby Luke » Mon Jan 23, 2006 9:38 pm
this was the adapter i was thinking of!!
:D
piccy here!!
Postby spondootre » Tue Jan 24, 2006 12:17 am
Cool, i'll try and get a momo boss as there seems to be a better range of wheels to go with them.
spondootre
Postby spondootre » Wed Jan 25, 2006 5:29 pm
I've spoken to a few places and they all can only get a momo compatible boss for a Ford Capri mk 1,2&3 and not the one for a transit. So i'm going to order that one, £29.95 + £6.95 p+p .
Malc
spondootre
