At least the 3 I had didn't..........
I can re-program your new key but....
I'm in Essex!
If you start to remove all the "Plastic" from your pump
you will soon see how to live-up the stop valve!
matt98 wrote:my mate lost his key some time ago,,so he took the imobiliser box out of the dash behind the glove box and his mate wiped it out and you no longer needed the chip in the key .. dunno how he did it tho.is this doable??
SteveHogg wrote:Hi,
I appreciate your comments so far and your reluctance to discuss such items on an open forum, however I am now at the point where I scrap the van if I can't get any help.
How can I tell if I've got the early system or pats2? Would you be willing to explain in a pm what I need to do. I don't want to remove or kill the pats system, just bypass it temporarily so I can get the van to a uk dealer to have the new key programmed.
Steve
Guy88 wrote:matt98 wrote:my mate lost his key some time ago,,so he took the imobiliser box out of the dash behind the glove box and his mate wiped it out and you no longer needed the chip in the key .. dunno how he did it tho.is this doable??
that is impossible on a turbo diesel with EPICSteveHogg wrote:Hi,
Steve
how old is it
If you have plastic cover its early pats, if its metal its PATS 2, either way remove the cover, find the stop solenoid, rest should explain itself
