MrMPuk wrote:It might be possivle to do it with that alternator but you would need to have a play, all I know is it's not the same as the one that was in the Tech how to. Pretty sure you need an un-rectified voltage.
MrMPuk wrote:Amp meter is completly different and I think you are just confusing yourself!
MrMPuk wrote:It's an un-rectifited voltage which means that as the engine speed varies so does the frequency of the output from the alternator, I could go into more detail but that kinda covers it!
yeah mate i'd agree with that!!MarkM wrote:This entire How to Subject needs to be re visited with *pictures* and alternatives as to connections if the original wiring doesn't work.
MrMPuk wrote:It does say in the tech how to that you need the 3 terminal alternator, but as said before you may still need to run the wire even if you have the right alternator.
The trouble is the How to is written from one person experience on one van and has we have found out they are not all the same!
