Fitting replacement arches
Postby AndyG » Sat May 27, 2006 8:03 pm
madmark wrote::shock: andy i am keeping my fingers crossed for you ,you have such a nice van there it needs dooing well! :wink:
Cheers madmark :D
I've got everything crossed :shock:
Hopefully the pictures SMC will be taking will show that it's not your usual "it's just a van" van :?
Postby madvanman » Sat May 27, 2006 10:10 pm
i cut out the old panel leaving a 5mm overlap then use a swaging(flange) tool on the edge on the new panel and punch holes around the edge of the existing panel, then weld through the holes to hold the new panel securely in place, then seam weld 1 inch leave a 2 inch gap, weld 1 inch etc.. repeat the weld-gap-weld until the whole seam is welded without putting too much heat in one spot and warping the panels. After welding i use a 10mm belt sander instead of a grinder to grind the welds, if the welding is good enough you can completely hide the fact that it has been welded even without covering with paint or primer, using the belt sander :D
madvanman
Customised!!
That's the proper way to do it...
Postby sportscott » Sat May 27, 2006 11:07 pm
Madvanman your a PRO!! that's the right way to do it. I would like a punch and swaging tool too but the once in a decenium that would use would'nt warrant the price of buying them. So have to do with what I've got :(
sportscott
Postby MrMPuk » Sat May 27, 2006 11:27 pm
You can get hand operated jogglers quite cheap, they are good enough for things like arches. The air operated ones are nice though.
