MK 3 Heater resistor
Postby motorwise » Mon May 01, 2006 9:05 pm
bondy wrote:is it in the same place on the mk 4 and 5 ?
smiley front onwards it's on the heater motor - all the earlier ones - yes
http://www.motorwise.net
motorwise
Postby 100ps_drw_hicube » Mon May 01, 2006 9:06 pm
my dads van had it by the starter motor :? :? still rotted just as quick :evil:
100ps_drw_hicube
Transit Abuser!!
Postby motorwise » Mon May 01, 2006 9:08 pm
100ps_drw_hicube wrote:my dads van had it by the starter motor :? :? still rotted just as quick :evil:
I think thats why they brought them indoors in '95 :D
motorwise
Postby 100ps_drw_hicube » Mon May 01, 2006 9:08 pm
nope mk5's are under the bonnet his is a late 97!!
100ps_drw_hicube
Transit Abuser!!
Postby motorwise » Mon May 01, 2006 9:12 pm
100ps_drw_hicube wrote:nope mk5's are under the bonnet his is a late 97!!
one of mine is a '95 and it's screwed to the heater motor on that one - thought they all were at this age
motorwise
Postby gemini » Mon May 01, 2006 9:16 pm
no, mines behind/below the o/s headlight
gemini
Postby AndyG » Mon May 01, 2006 9:20 pm
I think you'll find that earlier vans had them on/near the fan motor and later ones behind the offside headlamp and don't confuse it with the dim dip resister :lol: :lol: :lol:
Haven't checked my 2000 model as it's still working :!: maybe they've moved it again :roll: :lol: :lol:
Postby 100ps_drw_hicube » Mon May 01, 2006 9:23 pm
my 95 had it on the slam panel it's now been moved to the inner wing were it looks as new 8)
100ps_drw_hicube
Transit Abuser!!
Postby MarkM » Mon May 01, 2006 9:40 pm
Andyg wrote:I think you'll find that earlier vans had them on/near the fan motor and later ones behind the offside headlamp and don't confuse it with the dim dip resister :lol: :lol: :lol:
AndyG, yes they are very similar ;) but it was a coincidence the question about the lights with my post...reasoning was electrical and bad earth can have a knock on effect......think how many problems on this forum are a chaffed wire giving problems elsewhere.
MarkM
Postby AndyG » Mon May 01, 2006 9:52 pm
Yeah I fully agree with you :!:
I had a poor melted connector and gave all sorts of wierd symptoms :roll:
But I had to mention the dim dip resi. as no one else has :idea:
Postby Guy88 » Thu May 04, 2006 10:57 pm
Got a price for one today £38 + vat :shock:
Time to visit the scrappie :)
Guy88
Postby AndyG » Thu May 04, 2006 11:32 pm
Guy88 wrote:Got a price for one today £38 + vat :shock:
That must have been for a gold plated one :lol: :lol: :lol:
Try ringing a place that does Ford spares :idea: Like I have "Tomos" near me. :D
Postby gemini » Thu May 04, 2006 11:48 pm
should be £24 from ford, usually some on ebay
gemini
Postby Guy88 » Sat May 06, 2006 2:54 pm
Got one today, fitted it but still no luck, replaced both connectors and tested it, still only off and fast.
chacked voltage at ends of both wires and reads 0 :( is there anything between the switch and resistor thay could be broken, i guess there is no separate fuse for the slower speeds :?:
Guy88
Postby crazyscoot » Sat May 06, 2006 5:29 pm
Guy88 wrote:Got one today, fitted it but still no luck, replaced both connectors and tested it, still only off and fast.
Have you checked that it has a good earth?
Negative reality inversion
crazyscoot
