It fits no problem - however it does not match to the RS2000 alloy sump without modification (to get the starter to fit) and you have to change the pressure bearing to a larger one, what I did however is to get a spare actuator arm and weld the bearing section on top of the existing arm giving the extra travel - or taking up the slack, however you want to look at it.
Just fitted a transit clutch cable to mine as its longer and stops the sierra ones from melting on the exhaust manifold.
