timing belt gone?!! signs?
Re: timing belt gone?!! signs?
Postby dandare » Wed Dec 30, 2009 12:08 pm
nice one thanks, off to get rods and a feeler gauge. in the mean time if some one could number the valves so i know which to be working on as per the link. getting there. ta
transit 80 swb diesel. now a camper!!
dandare
Postby MrMPuk » Wed Dec 30, 2009 12:10 pm
1 is at the front.
Postby ake » Wed Dec 30, 2009 12:11 pm
MrMPuk wrote:1 is at the front.
You beat me to it :lol:
Postby dandare » Wed Dec 30, 2009 1:10 pm
:D thanks
do any of ye know of suppliers in glasgow or are ford the only folk for new ones? i'm needing 6 def just by looking at them. so i think i'd be as well renewing the lot. ford want 8quid each. just phoning scrappies to see if they have anything in!
dandare
Postby dandare » Wed Dec 30, 2009 1:28 pm
7-8 quid each seems to be the norm, guess i'll have to pay it as i can't get any scrappies with one in.
dandare
Postby dandare » Wed Dec 30, 2009 7:50 pm
ok peeps i'm nearly there. new rods in, belt on. i took the pins out gave a turn to fit the pins again the uppermost( fuel i think) is out by maybe 1 or 2 teeth of the cog. can i take the belt off and adjust the wheel manually? this one will sound daft but hey i need to know, does anyone have an image of the route for the alt belt? as i put it on the way i thought it should go but i'm left with way to much slack.
ta
dan
dandare
Postby MrMPuk » Wed Dec 30, 2009 7:55 pm
dandare wrote:ok peeps i'm nearly there. new rods in, belt on. i took the pins out gave a turn to fit the pins again the uppermost( fuel i think) is out by maybe 1 or 2 teeth of the cog. can i take the belt off and adjust the wheel manually?
You've done it wrong then, did you undo the bolts on the fuel pump pulley to tension the belt?
Postby Altransit » Wed Dec 30, 2009 7:58 pm
Courtesy of Guy88
Postby MrMPuk » Wed Dec 30, 2009 8:07 pm
Altransit wrote:Courtesy of Guy88
Actually courtesy of me but I let Guy88 borrow it.
Here is the routing of the alternator belt.
Postby dandare » Wed Dec 30, 2009 8:32 pm
thanks for the image dunno what i was thinking :shock: what happened with the pins, i set the tensioner back, undid the fuel to get the belt over, tightened fuel back, undid tensioner and went to remove pins but the fuel was jambed tight, guess my 9 mm is a bit off. so i started again, took the tension off, lined up, took pins out, put tension back on then gave it a turn to line up and thats when it's out a bit. thinking about it now i reckon it's the 9mm bit i used that could have led to the problem. i'll try another. see it's 9.5mm from the tech.drawing. i'll get one tomorrow and have another blast.
dandare
Postby MrMPuk » Wed Dec 30, 2009 8:36 pm
Why are you playing with the tensioner after you've taken the locking pins out? This is why they aren't lining up, it should all be done with the pins in place.
Postby dandare » Wed Dec 30, 2009 9:33 pm
yep, think i've misread the bit size but i'll get a new one to be certain. i think when the pins where in 1st time and the tension put on it, the 9mm(think mine is smaller) moved fractionally jamming it. i'll give it another blast in the morn.
ta
dan
dandare
Postby MrMPuk » Wed Dec 30, 2009 9:37 pm
I don't think the problem is the bits. From the way you've explained it I don't think you're doing it correctly but it's quite hard to understand exactly what you're doing.
Postby dandare » Wed Dec 30, 2009 9:58 pm
ok with all the pins in, tensioner pushed back to allow more space, i needed to undo the nut on the fuel to get the belt over. i then tightened the fuel nuts, undid the tensioner nut so that it tightened on the belt then tightened the nut. i then removed the pins bar the jammed 1. thats why i was messing about with the tensioner after the pins where out. well bar 1 :D .
sorry i do tend to rush thro my replies and not to clear.
i'll have another go in the morn.
ta
dan
dandare
Postby MrMPuk » Wed Dec 30, 2009 10:03 pm
Okay, that is what I thought. You need to have the fuel pump bolts undone to tension the belt, this is done with an allen key on the tensioner as per pictures 4 & 8 on the diagram above.
