clutch info req'd
Re: clutch info req'd
Postby psv-hgv-flt » Sun Feb 14, 2010 9:22 pm
:lol: :lol: :wink:
psv-hgv-flt
Postby godderidge » Mon Feb 15, 2010 12:00 am
You can only fit one size clutch from 99 on 241 mm The turbo clutch has a stronger pressure plate so is the best one to fit.
From 99 on the gearbox bell housing has bigger strengthening fins in side which means you can not fit the larger clutch unless you change the bellhousing to an earler one, or get the grinder out.
godderidge
Postby the_big_fact_hunt » Mon Feb 15, 2010 4:29 pm
just tried the main stealers £104+vat and not sure it is the right one!
wont be bothering with them then :lol:
found some on ebay for £50-60 +post so it looks like it will be a cheapie
just been out and had a look at it, the cable has no means of adjusting and the bearing is chattering a little bit, its driveable but slips if you try and welly it, and the pedal has dropped closer to the floor
Solve the World food problem.......... Feed the homeless to the hungry
2012 115T350
the_big_fact_hunt
Postby psv-hgv-flt » Mon Feb 15, 2010 4:42 pm
the_big_fact_hunt wrote:just tried the main stealers £104+vat and not sure it is the right one!
bring it hear and you can do it yourself over pit (i will help) got nowt on apart from dentist 2mozz, got a clutch you can have (just sitting there) :wink:
psv-hgv-flt
Postby the_big_fact_hunt » Mon Feb 15, 2010 6:13 pm
bloody tempting offer pal, but i'm back at work tomorrow, cheers anyway
2012 115T350
the_big_fact_hunt
Postby Altransit » Mon Feb 15, 2010 6:42 pm
With an offer like that, I would call in sick :lol: :oops:
Postby psv-hgv-flt » Mon Feb 15, 2010 6:52 pm
Altransit wrote:With an offer like that, I would call in sick :lol: :oops:
not much on (waiting for the mrs to burst :shock: ) :lol: should of been 14th.?? and i live opp garage. 8) 8)
psv-hgv-flt
Postby the_big_fact_hunt » Mon Feb 15, 2010 7:49 pm
Knowing my luck she'd drop while my gearbox is out :lol:
2012 115T350
the_big_fact_hunt
Postby psv-hgv-flt » Mon Feb 15, 2010 7:55 pm
the_big_fact_hunt wrote:Knowing my luck she'd drop while my gearbox is out :lol:
:lol: there will be others there. :lol:
psv-hgv-flt
Postby the_big_fact_hunt » Mon Feb 15, 2010 8:08 pm
well i had a look at it today, there is no way to adjust the cable, the pedal has dropped a bit, but still drives although if you push it too hard it slips OOOERRR :lol: and it has started chattering a little bit.
took the rubber bungs out of the box, everything looks ok, fork looks good, nice and clean all round, but i can disconnect the cable by hand quite easily :?
so i can only assume the clutch is really close to completely failing
2012 115T350
the_big_fact_hunt
Postby the_big_fact_hunt » Mon Feb 15, 2010 8:14 pm
forgot to mention, when i put it in 5th with the handbrake on and try to pull away it stalls
2012 115T350
the_big_fact_hunt
Postby psv-hgv-flt » Mon Feb 15, 2010 8:23 pm
the_big_fact_hunt wrote:forgot to mention, when i put it in 5th with the handbrake on and try to pull away it stalls
it will work better cold (slip more hot)
psv-hgv-flt
Postby the_big_fact_hunt » Mon Feb 15, 2010 8:31 pm
so if i can get over to fix it i have to drive really really fast to make more airflow to keep it colder 8) :lol:
2012 115T350
the_big_fact_hunt
Postby psv-hgv-flt » Mon Feb 15, 2010 8:34 pm
the_big_fact_hunt wrote:so if i can get over to fix it i have to drive really really fast to make more airflow to keep it colder 8) :lol:
errr, i was thinking put a face fan in the bellhousing. :lol: :lol: :lol:
psv-hgv-flt
Postby the_big_fact_hunt » Mon Feb 15, 2010 8:44 pm
guess you're right, fast and van dont necessarily go together :lol:
2012 115T350
the_big_fact_hunt
