bazw wrote:psv-hgv-flt wrote:dibs wrote:Do you know what I need to bypass to get the aircon working with the conversion? I read somewhere there is a relay that needs bridging but don't know where. Cheers
i did manual pump on a 1996 tourneo with a/c and it still worked but i did put a solinoid on the rev lever to pick the revs up a bit and wired it to the fans power.( they should still run regardless) as you will need to look at a montego or maestro 2.0 diesel engine (pump) for good advice and you will get the idea. is yours fully gassed up as compressor will not kick in if not gassed.
some one ban him he said "montego and maestro"
