CraigMac wrote:Ok thank you for your input !
Please let me tell you all where I'm at!!!
I have checked the conector behind the pump and it looks like new!
The timing belt has been replaced along with a new tensioner
The timing on the pump has been re checked and adjusted so that the 6mm pin slides in and out off the u shaped drilling on the pump and pulley.
I have tried stalling the van and am about to take her for a spin without the crankshaft sensor connected as advised by a member and will post my findings
The van will drive fine for around 5~10 miles fine then the red engine light comes on and the van goes into limp mode. I feel that the next stage would be to try and find someone up here in geordie lad who can pull the fault codes for me so that you guys have a better idea of what is going on.
So with that in mind if anyone can tell me of anyone within 50 miles of Newcastle who is able to pull the codes off for me that would be AMAZING as the robbing BAS#€RDS at ford want £85 + VAT which I really can't afford especially if there is more work to be done ie change the pump etc etc
Thanks guys .......Craig
These two pumps are interchangeable, so should have been fineCraigMac wrote:
Numbers are as follows mine:
DSA1096
21176KNG
8720A011A
And the new one :
DSA1096
11734EOG
8720A011A
Cheers Andy
