Andyg wrote:What you probably have is a 5.14:1 or a very very slow 5.83:1 and what you'd like is a 4.63:1
Check out your ID panel in the passenger footwell
on the right hand side of this panel, count down three rows and the fifth box across will be the axle ratio code letter and as long as no one has changed it since factory it will be correct
If it says 'K'= 5.83:1
If it says 'J' = 5.14:1![]()
If it says 'G'= 4.63:1(that's the one to go for when looking in the breakers
Try and also get the speed sensor off the gearbox if you find this axle as your speedo will be out otherwise
Guy88 wrote:This is the list iv got![]()
J=5.14
K=5.83
L=4.56
N=4.11
P=5.13
G=4.63
Is yours a smiley 6 studMarkM wrote:Andyg wrote:What you probably have is a 5.14:1 or a very very slow 5.83:1 and what you'd like is a 4.63:1
Going by the numbers and letters my axle is none of these and looking at how the letters seem to relate to the ratio then I should be lucky to do 50mph down a hill and it is just a little bit quicker than that. So what is the full list of letters to axle ratio
MarkM wrote:Guy88 wrote:This is the list iv got![]()
J=5.14
K=5.83
L=4.56
N=4.11
P=5.13
G=4.63
Ok well that makes no sense then...but it is Fords...look at the letters and you would think with the previous list that they would get a lot worse with the letter difference...I have the L axle so not too bad overall then
Andyg wrote:I suppose you're gonna tell us it's a diesel![]()
