transitgeoff wrote:Diesel and petrol racks are one and the same
geordie white van man wrote:I tried to swap the front axle over on my old mk3 swb van and it didnt work. I used a mk5 swb van as the donor vehicle. The axle itself bolts straight in but the shockers arent interchangable as the mk3 has a single nut at the top and the mk5 has 3 nuts at the top. I tried swopping the shocks over and the dont fit the stub axles. also the brakes are vented and bigger than a mk3 and you cant change them over either as they dont fit the stub axle either. I just ended up swapping the racks over which was easy, but then mine was a rack not a box![]()
If anyone fancies swapping the rear axles from a mk5 to put on a mk3 so the rear wheels sit inline with the front wheels they dont fit either. The shockers are on the opposite side of the axle as I was gonna swap that aswell.
leaf spring mounts are the same mateTransitwalla wrote:My main concern is offering the MK5 axle up to find the leafspring mountings are wider or narrower then the MK3 . . anything else can be worked on / around.
Luke wrote:leaf spring mounts are the same mateTransitwalla wrote:My main concern is offering the MK5 axle up to find the leafspring mountings are wider or narrower then the MK3 . . anything else can be worked on / around.
you reckon?? id have thought alter the axle's easierTransitwalla wrote:Looks like the best option is to make new shocker mounts for the chassis rails.
