diesel pump easy to fit???
Postby apples26 » Sat Aug 05, 2006 2:22 pm
its easy to rewire for the starter just runa wire from the ignition switch to the multi plu under the bonnet, had to do it on a mates p reg one the other week
apples26
Postby Nighthawk » Sat Aug 05, 2006 3:57 pm
yes m8, the pump and cam are pinned at the front of the engine. The flywheels timing pin location is just below the fuel filter.
Transit.........Job done
Nighthawk
Postby transitgeoff » Sat Aug 05, 2006 6:18 pm
to by-pass the pats and make the starter work,lift out the tray thing on the top of the dash,on the left, theres a yellow relay, throw it in the bin and join the 2 thicker wires :wink: done bundles no problems :D
transitgeoff
Postby AndyG » Sat Aug 05, 2006 10:38 pm
Andyg wrote:
Nighthawk wrote: recode the rim if it's a second hand pump ;)
Please clarify :!: :? :? :?
Are the pumps coded :?:
Postby transitgeoff » Sun Aug 06, 2006 9:39 am
the fuel pumps on Transits from 1997 to 2000 are coded, but its just a bolt on part, it clamps around the fuel stop solonoid and can be unbolted and thrown away,then it leaves you with the stop solonoid ready for a normal switchable 12volt feed to stop and start the engine :D hope that clarifies things :lol: also the wiring that goes to the unit to be thrown has 3 wires, if you have a test lamp one is a switched 12volt supply from the ignition switch and is just what you need :D ,if you try to put a 12volt supply to the pats unit it will blow,you MUST remove the said unit and bin it :D
transitgeoff
Postby apples26 » Sun Aug 06, 2006 10:55 am
transitgeoff wrote:to by-pass the pats and make the starter work,lift out the tray thing on the top of the dash,on the left, theres a yellow relay, throw it in the bin and join the 2 thicker wires :wink: done bundles no problems :D
oh thats handy to know m8 save taking the pump to bits and fiddling with wires
i take it it covers the pump immob also?
apples26
Postby motorwise » Sun Aug 06, 2006 11:13 am
see Geoffs other post for that :wink:
http://www.motorwise.net
motorwise
Postby AndyG » Sun Aug 06, 2006 8:51 pm
transitgeoff wrote:the fuel pumps on Transits from 1997 to 2000 are coded, but its just a bolt on part, it clamps around the fuel stop solonoid and can be unbolted and thrown away,then it leaves you with the stop solonoid ready for a normal switchable 12volt feed to stop and start the engine :D hope that clarifies things :lol: also the wiring that goes to the unit to be thrown has 3 wires, if you have a test lamp one is a switched 12volt supply from the ignition switch and is just what you need :D ,if you try to put a 12volt supply to the pats unit it will blow,you MUST remove the said unit and bin it :D
Does this apply to Lucas Epic :?:
Postby transitgeoff » Sun Aug 06, 2006 9:08 pm
no im afraid not :cry: its internal on them puppies :cry:
transitgeoff
Postby AndyG » Sun Aug 06, 2006 9:38 pm
transitgeoff wrote:no im afraid not :cry: its internal on them puppies :cry:
So I can't just fit a secondhand or even new pump on my van without a visit to Fords :?:
Is this why peeps have their original pump refurbished :?:
Postby apples26 » Sun Aug 06, 2006 9:46 pm
yes you do as above m8 its v easy to do, or any mechanic fitting the pump can do it for you
or then maybe the pats can be unbolted from the pump and fitted to the new pump?
apples26
Postby 100ps_drw_hicube » Sun Aug 06, 2006 9:58 pm
some garages have the gear to do it 8) the service manager has just left our fraud place now works for a local garage and they have the gear to do it shop around you could always try lucasss :lol: :lol:
100ps_drw_hicube
Transit Abuser!!
Postby AndyG » Sun Aug 06, 2006 10:09 pm
I'll find where the info is stored and do a swap :o :wink:
