accelerator pedal
Postby jonnyshag » Sat Aug 19, 2006 5:03 pm
no joy , maybe the pedal as packed in completle now
jonnyshag
Postby 100ps_drw_hicube » Sat Aug 19, 2006 5:34 pm
right one last try :roll: the big black circular switch that attaches to the pedal undo this from the pedal unit blow it out with an airline clean as much as you can watch out for the sticky seal dont lose or break! this ,ight cure your problems if not down teh scrappy's you go :( :( unless you have £149 at fords :shock:
100ps_drw_hicube
Transit Abuser!!
Postby jonnyshag » Sat Aug 19, 2006 8:53 pm
100ps_drw_hicube wrote:right one last try :roll: the big black circular switch that attaches to the pedal undo this from the pedal unit blow it out with an airline clean as much as you can watch out for the sticky seal dont lose or break! this ,ight cure your problems if not down teh scrappy's you go :( :( unless you have £149 at fords :shock:
thats what i took of that black circular thing , i put everything back together and it wont rev , ive messed around with the connections just cant get it to work , do you get the complete pedal from fords
jonnyshag
Postby 100ps_drw_hicube » Sat Aug 19, 2006 9:04 pm
yep :D but for what it is it's alot of ££££ :idea: try lucas they might be able to do something or get the individual switches :D
100ps_drw_hicube
Transit Abuser!!
Postby jonnyshag » Sat Aug 19, 2006 9:09 pm
yeah i could try lucus , theres a lucus depot in hull
jonnyshag
Postby 100ps_drw_hicube » Sat Aug 19, 2006 9:17 pm
worth a try as a switch might only be £30 :? :? or they might tell you what the fault is :? :?
100ps_drw_hicube
Transit Abuser!!
Postby jonnyshag » Sun Aug 20, 2006 2:47 pm
is there anything you need to reset or is there any fuses , there is a live coming from the plug and iyf you turn the engine off put the accerlater right down then start it , it will rev to the max then go back to idle and cant rev it again :?
jonnyshag
Postby 100ps_drw_hicube » Sun Aug 20, 2006 2:52 pm
:? :? dunno mate i have never had a problem whenever i get one from a scrappy i just unplug mine plug 2nd hand one in test to see if it works then plug mine back in and have no probs something sounds not right with yours :? :?
100ps_drw_hicube
Transit Abuser!!
Postby jonnyshag » Sun Aug 20, 2006 3:03 pm
it must of been on it way out and with dis-connecting it must of packed in for good, it looked to be sumot to do with that cicuarle thing
jonnyshag
Postby 100ps_drw_hicube » Sun Aug 20, 2006 3:08 pm
:? :? i would defo try to get just the switch part :) if not find a scrappy for the pedal because if it's not the pedal then it's a lot of ££ wasted at fords :( is north west transitsstill open in manchester they had ton's of mk5 td's in when i last went :D :D
100ps_drw_hicube
Transit Abuser!!
Postby jonnyshag » Sun Aug 20, 2006 3:17 pm
dont suspose you still have there phone number?
jonnyshag
Postby 100ps_drw_hicube » Sun Aug 20, 2006 3:22 pm
:? :? hang on mate i had a card of theres somewhere give me 5 mins :D
100ps_drw_hicube
Transit Abuser!!
Postby jonnyshag » Sun Aug 20, 2006 3:25 pm
this is that switch unit, ive taken it apart , but cant find anything obviously wrong
jonnyshag
Postby 100ps_drw_hicube » Sun Aug 20, 2006 3:28 pm
ye looks same as mine but different colour wires bugger cant find tehre details will keep looking :D
100ps_drw_hicube
Transit Abuser!!
Postby AndyG » Sun Aug 20, 2006 3:32 pm
jonnyshag wrote:ive messed around with the connections just cant get it to work , do you get the complete pedal from fords
:shock: :shock: :shock: Changed their order around :?: what do you mean :?: :!: :shock:
Isn't there two plugs on the older unit :?:
