1999 (V-Reg) Banana Engine into 1997 (R-Reg) Van???
Postby geordie white van man » Wed Aug 30, 2006 11:55 pm
My T reg transit runs a banana manifold type engine. Should be a straight swap, piece of piss, should only take a couple of hours to do. Good luck mate, :D
Check out our brand new community!
http://buspreservation.phpbb.net/index.php
Postby 100ps_drw_hicube » Thu Aug 31, 2006 8:20 am
engine mounts could be different so might take more than a couple of hours if ya cant get the buggers off :twisted: :twisted: :twisted:
100ps_drw_hicube
Transit Abuser!!
Postby tractive-effort » Fri Sep 01, 2006 7:34 pm
Thanks for all your help; just one other thing before I change the engine (probably won't be for a few weeks actually).
I noticed today my current lump is exhausting a fair bit of oil vapour out of the dipstick tube, once the dipstick has been removed and the engine is up to temperature. As I recall this is an indication of exceedingly worn piston rings is it not???
tractive-effort
Postby 100ps_drw_hicube » Fri Sep 01, 2006 7:45 pm
crankcase pressure :wink:
100ps_drw_hicube
Transit Abuser!!
Postby MrMPuk » Fri Sep 01, 2006 9:39 pm
You will get oil vapour out the dipstick hole, that's why there is a stick blocking it!
Postby gemini » Fri Sep 01, 2006 10:06 pm
MrMPuk wrote:You will get oil vapour out the dipstick hole, that's why there is a stick blocking it!
not on a good engine you wont :?
gemini
Postby Guy88 » Fri Sep 01, 2006 10:08 pm
Our MK5 does it. its only got 39000 on the clock :?
2005 Ford F250 Super Duty
1992 MK3 ambulance
1980 A Series crew cab
1984 A series RB44
LIVIN' LOUD
Guy88
Postby gemini » Fri Sep 01, 2006 10:13 pm
Guy88 wrote:Our MK5 does it. its only got 39000 on the clock :?
that wont be run in yet :lol:
gemini
Postby MrMPuk » Fri Sep 01, 2006 10:47 pm
All diesels breathe quite heavly, even by new van with zero mileage. Leave the dipstick out and it makes a hell of a mess!
Postby gemini » Fri Sep 01, 2006 10:53 pm
do they :roll: thats spitting oil out, not breathing
gemini
Postby MrMPuk » Fri Sep 01, 2006 11:18 pm
They spit oil out because they are breating.
Postby gemini » Fri Sep 01, 2006 11:24 pm
MrMPuk wrote:They spit oil out because they are breating.
no, they may spit a bit of oil because the oil pump is pumping oil round the engine, breathing is totally different, you really must learn about engines
During break-in, a small amount of compression blow-by, oil-fuel dilution, and oil consumption will be experienced. This is perfectly normal and quite common in new engines. Although acceptable at first it is imperative that these undesirable attributes be as close to zero as possible after break-in has been completed
gemini
Postby MrMPuk » Fri Sep 01, 2006 11:30 pm
We shall have to agree to disagree once again, but neither of us have seen the engine so can't really comment.
Postby gemini » Fri Sep 01, 2006 11:40 pm
excessive crankcase pressure in an engine can be a few things, head gasket leaking from a cylinder to an oil channel, worn rings/bores, cracked piston
gemini
Postby 100ps_drw_hicube » Sat Sep 02, 2006 1:25 am
engine is fooked basically
100ps_drw_hicube
Transit Abuser!!
