Transit 2.5 Turbo Diesel diagnose plug
Re: Transit 2.5 Turbo Diesel diagnose plug
Postby robbie.cee » Mon Jun 29, 2015 8:41 pm
And yes Live data/sin list is what Im aiming for!...
Must get new ect sensor before Saturday !
Had
X-Reg Mk5 150ps 3.0 ESSEX V6
MAKE IT FIT
robbie.cee
Postby martynx » Tue Jun 30, 2015 7:15 am
On the Ecu the extra connector under a plastic cover is called a J3 port , it's how Ford would program the Ecu at the factory and sometimes , mainly in the USA , a module would attach to it to tune it. It's not really a reprogramming port as such as prior to '2000 most chips in most ecu's were one time programmable, so tuning involved a chip change or an add. on module. Most tuning on this series of ECU is done on US models so it may be tricky to find a good solution , I'd personally seek out a cheap aftermarket ECU to play with.
martynx
Postby robbie.cee » Tue Jun 30, 2015 10:18 am
Yes Thats the socket. So even on a uk ecu still not the one for use to re map or do ypu physically fit another eprom in the ecu when you do your magic?
Had
MAKE IT FIT
robbie.cee
Postby martynx » Tue Jun 30, 2015 10:24 am
You connect and leave in place a module
martynx
Postby martynx » Tue Jun 30, 2015 10:26 am
That era of ECU isn't my area of expertise though ;) nor are petrols generally.
martynx
Postby robbie.cee » Tue Jun 30, 2015 10:59 am
Ah yes I believe petrol chips got a new eprom or eeprom ! Wonder if i got one, and piggyback onto orig chip, but Lifted pin 1 or whichever is power, and put via 2 way switch if i could have a standard and sport switch? Do you think it would work ?
Had
MAKE IT FIT
robbie.cee
Postby robbie.cee » Tue Jun 30, 2015 11:01 am
And fpr anyone interested in this sort of stuff you can erase data on an eprom if you uncover the glass window on it and shine a uv light onto the chip for about half hour!
Usually has a sticker over the window in center on top side
Had
MAKE IT FIT
robbie.cee
Postby martynx » Tue Jun 30, 2015 1:49 pm
robbie.cee wrote:And fpr anyone interested in this sort of stuff you can erase data on an eprom if you uncover the glass window on it and shine a uv light onto the chip for about half hour!
I'd love to tune it for you Robbie but not sure where to start really although I do have the light type eprom eraser - ( didn't know yours had that type of chip :wink: ) Anyhow ditching the factory ECU would allow you to map it yourself probably , they are so simplified compared to OEM stuff & more ideal as you are having issues getting your factory setup running right .. Limbak is merrily mapping away on his ST170 engined Lada Riva that has an aftermarket ECU......
Info from here looks quite useful - http://passionford.com/forum/general-car-related-discussion/475000-24v-boa-tuning.html
Heres what I saw -
You can fairly easily get 350bhp out of them and then with a rebuild for forged pistons retc 450/500.
To get this you do need to turbo the engine either single turbo, twin turbo supercharged. All are effective depending on what you want.
Alternatively if you want to stay na you can get around 230ish by changing injectors vauxhall v6 ones, changing cams to bob cams, i have changed my management to ensure fuelling is correct which transformed the car from the standard ecu. You can also change the plenum chamber to give better flow. Lots you can do depending how far you want to go.
Have a look on http://www.fordpower.org.uk/index.php there is lots and lots of information on there.
martynx
Postby robbie.cee » Wed Jul 01, 2015 12:12 pm
Good info there...
Re uv light any blacklight will do it dont need uv clarifier type used to bake nailpolish and kill algae!
Had
MAKE IT FIT
robbie.cee
Postby MinorMatt » Wed Jul 01, 2015 12:25 pm
Megasquirt (cheap DIY) or Omex (expensive but plug and play) seems to be the way to go for most things...
My Zetec minor will be on meagsquirt
Postby robbie.cee » Wed Jul 01, 2015 12:26 pm
That answers that then, remap petrol is an ecu buttplug not a new chip inside!
Had
MAKE IT FIT
robbie.cee
Postby Mr RVM » Wed Jul 01, 2015 1:24 pm
MinorMatt wrote:Megasquirt (cheap DIY) or Omex (expensive butt plug and play) seems to be the way to go for most things...
Where are we going with this :shock:
Mr RVM
Postby robbie.cee » Wed Jul 01, 2015 1:30 pm
Vanporn
Had
MAKE IT FIT
robbie.cee
Postby MinorMatt » Wed Jul 01, 2015 3:55 pm
I see you have got in on the act of bastardisation then Gaz?
Postby robbie.cee » Wed Jul 01, 2015 7:02 pm
Prey tell...!
Had
MAKE IT FIT
robbie.cee
