Wheel Alignment
Re: Wheel Alignment
Postby Kedishen » Tue Oct 11, 2011 3:41 pm
Maybe so, however I will give it a try and report back. Can't be any worse than having to pay someone else to make a balls up of the tracking.
Livin' in me van in Portugal.
'93 Mk4 TD 150L Hitop Custom Camper
100ps Epic blue spot
Kedishen
Re: Wheel Alignment
Postby MinorMatt » Tue Oct 11, 2011 3:43 pm
Ps. i think the trackrite is probably easier to use and its cheaper too!
Re: Wheel Alignment
Postby Kedishen » Tue Oct 11, 2011 3:45 pm
Trackrite looks very similar to trackace :o
Actually, identical... ?
http://www.gunson.co.uk/item.aspx?cat=676&item=7258
Kedishen
Re: Wheel Alignment
Postby MinorMatt » Tue Oct 11, 2011 3:49 pm
I meant the one you drive over...
I was looking at the trackace just last night and I thought there were too many parts to lose/break as well as the hassle factor
Re: Wheel Alignment
Postby Kedishen » Tue Oct 11, 2011 4:18 pm
Looks interesting that one.
Since i already bought the other one, looks like my decision is already made. I am hoping I didn't buy the wrong one :o
Kedishen
Re: Wheel Alignment
Postby Kedishen » Mon Oct 17, 2011 11:08 am
Well, the Trackace system arrived next day and what can I say?
It was easy to setup, easy to interpret and produced the same result over and over again.
The only bad point about it really is that it doesn't currently have the ability to line up a wheel with the rear wheels, but that will be releasing this function soon.
Well worth the money imo.
Kedishen
Re: Wheel Alignment
Postby Kedishen » Mon Oct 17, 2011 11:13 am
18' is 2mm (iirc)
I very much like 5' toe in (60' in a degree). However, I think it is abit close to absolute 0 and will probably increase it to 10'. However, the tyres are showing signs of scuffing on the outside edges with this setting.
I spoke to a few garages and they all said they set transit 92-94 models to 1degree toe out. Does anybody agree with this setting? I cannot seem to get any sort of answer from qualified ford technicians, unless there are any roaming around on here? I would very much like to set it to factory settings.
Kedishen
Re: Wheel Alignment
Postby btvanowner » Fri Oct 28, 2011 12:04 am
it used to be rule of thumb rear wheel drive...parallel
front wheel drive... toeing out
as when the front wheel drive takes up drive they toe in towards parallel
ACCIDENTS ARE NOT FUNNY UNLESS ITS SOMEONE ELSE.....THEN ITS HILARIOUS
btvanowner
Re: Wheel Alignment
Postby knighty1981 » Fri Oct 28, 2011 12:29 am
slight side note... but on topic....
once your front wheels are worn unevenly... that's it... they'll never flatten out even... and you'll struggle to get the tracking right...
best bet is to swap them onto the back ;)
knighty1981
Users browsing this forum: transit-richard
