Mondeo Dash ...again.
Postby fitzy » Sat Jul 08, 2006 9:36 pm
I already had the cable (grey/black) from the alternator to the large connector next to the battery, but it didn't have th white/black wire going in to the cabin, so i just ran a new wire from the alternator (grey/black) connection in to the cabin behind the dash and connected it staright to pin # 8 started her up and "hey presto" rev counter worked perfectly first time.
Fitzy :wink: :D :wink:
fitzy
Postby davidat19 » Sun Jul 16, 2006 8:24 pm
Not having read all 11 pages yet, do I need clocks from a petrol mundane (mine is a 99 twinc 8v) and will it still show the correct speed?
davidat19
Postby MrMPuk » Sun Jul 16, 2006 8:26 pm
You will need perol ones then, but you will need to check if you need cable or electronic speedo.
Postby Luke » Sun Jul 16, 2006 8:29 pm
i think all petrols(dohc) are electronic speedo :?
Postby MrMPuk » Sun Jul 16, 2006 8:33 pm
Worth checking then!
Postby davidat19 » Sun Jul 16, 2006 8:49 pm
defimetly electronic..what price do they go for?
davidat19
Postby Guy88 » Sun Jul 16, 2006 9:29 pm
i got mine for £10 at a scrappie
2005 Ford F250 Super Duty
1992 MK3 ambulance
1980 A Series crew cab
1984 A series RB44
LIVIN' LOUD
Guy88
Postby geordie white van man » Sun Jul 16, 2006 10:38 pm
Got mine working nicely apart from now the fuel gauge is reading wrong. Only the original fuel gauge works as it should. Ive tried 3 different mondeo fuel gauges and all of them give different readings! Ive just put £40 of diesel in and its still only reads 1/4 full and acts like a windscreen wiper when driving along! Any ideas anyone?
Check out our brand new community!
http://buspreservation.phpbb.net/index.php
Postby Guy88 » Sun Jul 16, 2006 10:46 pm
Mine reads right but it does wander a bit as it hasnt got a voltage stabiliser in it
1992 MK3 ambulance
1984 A series RB44
LIVIN' LOUD
Guy88
Postby ghost » Thu Aug 02, 2007 2:11 am
All Mondeos including diesel up to model revamp have cable speedo.Late 97-98 onwards new shape models are electronic I've found.
I'll scavenge the clocks & plugs out of any dead Mondeos I get and post a link.
Fitted clocks to my 98 from a 93 donor tonight,rev counter not working so looking forward to a little wiring...
ghost
Postby sportscott » Fri Aug 03, 2007 10:38 pm
OxtonyxO wrote:ok fitted my dials from a d mondeo all ok took out the abs and air bag lamps all ok ran a wire from the alternator b/w to pin eight all ok started her up and the rev counter worked, sort of
the problem is this the rev counter is only multiplying by 100 not by a 1000
so on tickover it is reading 7000 instead of 700
but the needle is reving with the engine
any ideas please peeps
thank you tony
ps my dash is an electronic speedo
with the late type alternator with the plug on the side :roll:
I'll add my bit at this point as have'nt read all the posts further. A rev-counter works from a wire connected to the ignition circuit and a wire from the un-rectified alternator and grounded of course. A generic type rev counter is adjustable as to how many poles the alternater has. In this scenario where gauge is mis-reading is due to it receiving wrong signal from alternater. I fitted a rev counter recently in my boat and it was due to the high price of original equipment that got me looking into how they worked. But in fact should in theory be able to hook it up to my Di motor with only two wires and earthed then flick through the settings to find out how many poles a Transit alternator has :?
Transit the everyday mans van....
sportscott
Re: Mondeo Dash ...again.
Postby R0SSY » Mon Mar 16, 2009 10:32 pm
OK flicked through most of this being 11 pages...the only among other things its not clear what the gaol is...
Is it to fit a Mondeo complete dash in to a transit or can you remove the rev counter and it fit somehow in to a none rev counter transit dash?
BTW I have a 1998 S reg will that be cable driven speedo?
Rossy
He who runs in front of me will get tyred, he who chases me will get exhausted, he who drives my van like hell, will get their very quickly!
R0SSY
Postby trigger » Tue Mar 17, 2009 12:33 am
S reg will prolly be electronic speedo.
Mk5 Transit the daddy
trigger
Postby R0SSY » Sat Mar 28, 2009 9:57 pm
trigger wrote:S reg will prolly be electronic speedo.
Yep its electronic speedo so will a electronic Mondy Dash do right in or are there mods if so can someone post a simple "how to"
For old cable ones and for Electo Speedo ones?
Cheers.
Rossy
R0SSY
Postby trigger » Sat Mar 28, 2009 10:31 pm
Electronic Mondy clocks will fit straight in but like others have said the fuel guage may read wrong, when i fitted Mondy clocks to my old van i was lucky and the fuel guage read correctly, some are ok some are not.
trigger
