Mondeo Dash ...again.
Re: Mondeo Dash ...again.
Postby R0SSY » Sun Mar 29, 2009 10:57 pm
trigger wrote:Electronic Mondy clocks will fit straight in but like others have said the fuel guage may read wrong, when i fitted Mondy clocks to my old van i was lucky and the fuel guage read correctly, some are ok some are not.
So plugs are same etc... no swapping wires around? Just take old one out and fit Mondy one in?
Oh also does it have to be out of a diesel or any electronic speedo one?
Rossy
He who runs in front of me will get tyred, he who chases me will get exhausted, he who drives my van like hell, will get their very quickly!
R0SSY
Postby trigger » Sun Mar 29, 2009 11:20 pm
All the connections are the same, you may have to run a wire from the alternator to terminal 8 on the big multiplug, if your van is diesel then you will need a diesel rev counter, they are marked just under the needle D for diesel and 4 or 6 for petrol engines, also diesel rev counters are marked up to 6000 revs petrol ones up to 8000 revs.
Mk5 Transit the daddy
trigger
Postby shadyocuk » Sat Apr 25, 2009 8:15 pm
Might as well add my results to this long thread. An provide answers to some questions I have seen.
I have just fitted a cable drive instrument pack from a 97 TD mondeo to my cable drive 97 mk5 and am very happy with the results. I have taken the voltage regulator from the mk5 instrument pack and used it on the mondeo one (just needed to break the contacts on the mondeo pcb, and push the regulator into the slot).
my mk5 is a custom and allready had the extra alternator wire , so was just plug and play.
Rev counter works fine
Speedo works fine
Temp Guage works fine
Fuel guage appears to be ok and does not move about whilst driving
Battery, Oil pressure, ABS,Airbag, Main beam and Indicator sensor lights work fine and are the correct symbols
Water in fuel sensor light works and simply swaping the bottom left 4 symbol card from the mk5 gives you the correct symbol.
The fog light sensor light comes on when the fog lights are off and goes off when they are switched on
(have just removed the bulb at present as the light on the fog light switch lights up when they are on anyway)
The trailor indicators sensor light activates an orange clock type symbol on the Mondeo clocks and initial only gets power before the engine is started, but by altering the pcb (cut one track and solder a new one from the main beam ground ) this now works as it should. I can live with the incorrect symbol for this as I know what it means.
To get the correct mileage reading I just swaped the complete number barrels over as they are exactly the same size.
I can also confirm that you do not need to remove the steering wheel , just remove the upper and lower cowlings and undo the two stalks and let them hang down whilst gently flexing the instrument panel surround past the steering wheel.
Shady
shadyocuk
Postby trigger » Sun Apr 26, 2009 2:39 am
Removing the steering wheel does make the job a lot easier unless it has an airbag mine does not, as mine has the electric pack mine has the high series wiring loom so the wire was already there so was just plug and play, however i used genuine Transit clocks not Mondy ones so naturally everything worked fine. :)
trigger
Postby bez » Thu Jul 02, 2009 3:25 pm
is there any thing you can add to make the rev counter read right mine reads 4800 rpm on tick over?is there a diode or some thing?
if in doubt flat out!
bez
Cosworth Powered
Cosworth Powered
Postby AlanN » Thu Jul 02, 2009 11:05 pm
Have you got the right counter, diesel for diesel etc etc... petrol for petrol 4 pot or 6 pot...
Postby bez » Thu Jul 02, 2009 11:54 pm
yep its derv every thing else works
bez
Cosworth Powered
Cosworth Powered
Postby AlanN » Thu Jul 02, 2009 11:58 pm
does pin 8 on the big plug go to the 3rd connection on the alternator then... Is it the right alternator to give the right signal
Postby bez » Thu Jul 02, 2009 11:59 pm
no it the other alt with the 2 pin plug on side
bez
Cosworth Powered
Cosworth Powered
Postby AlanN » Fri Jul 03, 2009 12:02 am
You need to change over to the 3 connection type of alternator. It has a connection which basically gives the counter signal :D
Postby bez » Fri Jul 03, 2009 12:08 am
how come proper transit ones work?
bez
Cosworth Powered
Cosworth Powered
Postby AlanN » Fri Jul 03, 2009 12:13 am
Ive only seen diesel MK5's with a 3 terminal alt with a counter, I think they get changed for the other type (petrol) when they go wrong by the garage, not a problem for the petrol one the signal is from the coil. Mind you, most transit dont have a counter, so most people wouldnt notice. You may have to have a certain set of dials for the 2 wire type
Re: Re:
Postby AndyG » Fri Jul 03, 2009 12:15 am
Andyg wrote:
Andyg wrote:STOP :!: Good news :D I've just checked mine under the bonnet and guess what :?: Same alternator :o Mine already has a rev counter :D . On the side of the alternator there's 2 wires. The bottom one is the WHITE/BLACK cable that is already there. Sorry I can't do photos :( . Have you got a white/black cable on your 16 pin connector :?: Pin 8 :?:
:lol: I can do photos now :D :wink:
Postby bez » Fri Jul 03, 2009 12:18 am
is the alt i need a mk4 then 3 wire and it will work?
bez
Cosworth Powered
Cosworth Powered
Postby AndyG » Fri Jul 03, 2009 12:18 am
