What did you do to your mk 3/4/5 today.
Re: What did you do to your mk 3/4/5 today.
Postby MinorMatt » Mon Sep 22, 2025 10:29 am
gotgcoalman wrote:Ok chaps.
Front x member inner bit is absolute swiss cheese.
Started trying to make the entire thing in one piece.
It's proving be a pain in the bottom due to it curving slightly.
Is this the correct part no for the inner bit?
As in the bit in the engine bay.
Not the bit behind the bumper.
46751438
Cheers chaps
Sent from my LE2101 using Tapatalk
I have a few front X member panels in stock
but this is what you want
https://www.ebay.co.uk/itm/257009241099 ... R4bp-YuuZg
Can't comment on quality though
Postby gotgcoalman » Mon Sep 22, 2025 4:44 pm
Bugger..........
In the end I replaced it Matt using sheet steel. (Not washing machine sides)
The original one looked like a patchwork quilt.
Hoping to get the welding finished over the next day or so (weather permitting)
Too bloody quiet :shock:
gotgcoalman
Postby gotgcoalman » Thu Oct 09, 2025 4:59 pm
Been to MOT station.
Bloody thing was working when I set off
Vroom vroom
gotgcoalman
Postby gotgcoalman » Wed Oct 22, 2025 5:04 pm
Header tank appears to have some age related stress cracks.
It's been a bit weepy today.
I shall apply some mix up araldite snot and call it good.
Good old mk5 engineering.
You can fix them at the side of the road with 2 paperclips,an elastic band and several tie wraps of various sizes.
gotgcoalman
Postby Altransit » Wed Oct 22, 2025 7:10 pm
gotgcoalman wrote:Good old mk5 engineering.
In my day, it was several different sized jubilee clips, lots of bits of wire, nuts and bolts, and one of those fan belts that you could cut to size :P :lol:
Postby gotgcoalman » Wed Oct 22, 2025 9:57 pm
OMG I can remember those fan belts.
gotgcoalman
Postby Altransit » Thu Oct 23, 2025 9:56 am
gotgcoalman wrote:OMG I can remember those fan belts.
I think mine is still in the spares box, under the front seat of the Mini Van :lol:
Postby MinorMatt » Thu Oct 23, 2025 12:35 pm
So can I and you are way older than me :lol: But I remember cars with crash gearboxes, dynastarts and magnetos too
Postby cherniy_chack » Thu Oct 23, 2025 6:23 pm
About a month ago, I finished body work on my Transit at my dacha and drove it to Kyiv, leaving my Nissan X-Trail in the garage.
After the X-Trail, the Transit seemed "sluggish" to me, and I started thinking about this problem.
Furthermore, I was bothered by the fact that after replacing the temperature sensor, the temperature gauge needle was on the right side of the dial, near the red section.
I borrowed a non-contact pyrometer from my boss and started monitoring the thermostat housing temperature with it.
Typically, during city driving, it's around 75 degrees Celsius; during fast highway driving, it was less than 90.
I also measured the exhaust manifold temperature at all cylinders.
The hottest exhaust is at cylinder three, cooler at cylinder two, and "colder" at cylinders one and four. I adjusted and lowered the injector opening pressure several times, more or less equalizing the exhaust temperature across the cylinders, and the car ran faster.
However, increasing the opening pressure on cylinder three failed to lower the exhaust temperature—the injector simply stopped opening.
I suspect the third injector is the problem; I'll need to test it with a press and possibly replace it. Also, check the operation and opening pressure of the remaining injectors.
After a summer outage for repairs, I developed problems with the parking brake cable. An inspection revealed that the plastic coatings on the cables were peeling.
I went to the auto market and bought new cables; I have a rear axle from a 2007 Transit. I also bought a "FORD" badge for the hood.
Two cables cost 750 hryvnias, the badge almost 500! After installing new cables, I needed to adjust the parking brake, but I couldn't do it—three years ago, when replacing the rear axle and installing the cables, I broke the part with the left-hand thread.
I had previously welded the broken part back on and somehow adjusted it, but now I wanted to restore the functionality of the adjustment unit.
But where can I find a shackle with a left-hand M8 thread?!
I found a solution.
I bought a cable tie at a hardware store.
The end with the left-hand thread had a hook, not a ring. I heated it with a torch, bent it, welded it, machined it inside and out, and I had a complete replacement for the broken part.
cherniy_chack
Postby cherniy_chack » Sun Oct 26, 2025 4:20 pm
Today at the dacha, I got out the press and started checking the injectors.
The most correctly adjusted injector was on cylinder three!
I started selecting and adjusting the old injectors and the ones removed from the engine.
Eventually, I managed to select and adjust three more injectors.
The exhaust temperature at idle has leveled out, and the engine is running smoothly.
I didn't check the temperature under load, or rather, immediately after.
cherniy_chack
Postby cherniy_chack » Mon Oct 27, 2025 6:35 pm
Happy anniversary to all Ford Transit owners and drivers – today the brand turns 60!
YouTube just told me about it.
Today I measured the engine exhaust temperature after a trip from home to work. Cylinder 3 still shows the highest temperature, and therefore, efficiency. But the others aren't far behind.
It might be possible to slightly reduce the opening pressure on the remaining injectors and even out the efficiency.
I'm continuing to experiment with tightening the fuel pressure corrector screw on the high-pressure fuel pump. As I tighten it, fuel delivery increases, including at low rpm, and low-end torque increases.
cherniy_chack
Postby hetman » Fri Nov 07, 2025 8:06 pm
Greetings, folks. I haven't been here in a few years I believe. My 1995 Transit has been sitting on jack stands for nearly 2 years now as I've been too busy to tackle the next unexpected project and that is a problem with overheating of the engine (again - I thought I'd solved that problem many years ago but after I lent my van to someone for 6 months, it came back with overheating problems which I can't resolve). So, I have undertaken the project of removing the head in the hopes that the problem is only a faulty head gasket. I know it could also be a cracked head or block. In any case, I need to figure out what the problem is before I can use the van.
So, the first question I have is how do I remove the fuel injectors? What kind of tool is required to do this?
Thank you.
Mike
hetman
Postby gotgcoalman » Fri Nov 07, 2025 8:30 pm
hetman wrote:Greetings, folks. I haven't been here in a few years I believe. My 1995 Transit has been sitting on jack stands for nearly 2 years now as I've been too busy to tackle the next unexpected project and that is a problem with overheating of the engine (again - I thought I'd solved that problem many years ago but after I lent my van to someone for 6 months, it came back with overheating problems which I can't resolve). So, I have undertaken the project of removing the head in the hopes that the problem is only a faulty head gasket. I know it could also be a cracked head or block. In any case, I need to figure out what the problem is before I can use the van.
Thank you.
I've only had to "wiggle and pull" in the past.
Undo the clamp, injector pipe and leak off pipe then work left right left right while applying upward force.
I might have been one of the lucky few that never came across a particularly stuck one though.
Maybe spray with plusgas the night before
gotgcoalman
Postby hetman » Sat Nov 08, 2025 11:35 am
Mike
hetman
Postby hetman » Sat Nov 08, 2025 11:36 am
Thank you.
Thank you, sir. I will try that today.
Mike
hetman
