Mondeo Dash ...again.
Re: Mondeo Dash ...again.
Postby AlanN » Fri Jul 03, 2009 12:22 am
My mk3 has a MK4 engine in it, with a 3 bolt on terminal alternator (on the top) and I run mondeo MK1 dials, works fine!!!!
Postby bez » Fri Jul 03, 2009 12:24 am
sounds like a plan then ill hunt 1 down :lol:
if in doubt flat out!
bez
Cosworth Powered
Cosworth Powered
Postby bez » Fri Jul 03, 2009 12:26 am
Andyg wrote:Image
thats the one i have and iv conected to the bottom wire like it says
bez
Cosworth Powered
Cosworth Powered
Postby bez » Fri Jul 10, 2009 12:17 pm
right fitted the 3 wire alt at a cost of £40 and still the same.so does any one else no how to make it read right
bez
Cosworth Powered
Cosworth Powered
Postby AlanN » Fri Jul 10, 2009 12:36 pm
The spare connection on alternator goes to pin 8 on the big plug, yes.
What volts did have on tick over?
Ive had this someone else on here too and now I cant find it...
I think I had something like 7.6 volts AC on tickover
Postby bez » Fri Jul 10, 2009 12:44 pm
not looked mate my meters not with me,theres got to be a way to make it read right,we use to have to mod the rev counter on mk2 fiestas when running them zetecs on carbs
bez
Cosworth Powered
Cosworth Powered
Postby AlanN » Fri Jul 10, 2009 12:51 pm
Sounds odd to me...
Postby bez » Fri Jul 10, 2009 12:56 pm
one more thing dont no if its connected when the ignition is off or on the rev counter goes around to full
bez
Cosworth Powered
Cosworth Powered
Postby AlanN » Fri Jul 10, 2009 1:01 pm
:shock: :shock: :shock: Should drop to 0 :lol:
Postby bez » Fri Jul 10, 2009 1:11 pm
thats what i was thinking.dont no what to do now :lol:
just been out and removed the white and black wire switch power on and it went round off the clock.i then turned the power off and it when back down to 6000rpm. :?
bez
Cosworth Powered
Cosworth Powered
Postby bez » Fri Jul 10, 2009 1:38 pm
just tryed some petrol clocks and they read the same.never mind cant be bothered any more so standed clocks back in.
bez
Cosworth Powered
Cosworth Powered
Postby Dave12590 » Sat Jul 11, 2009 12:23 pm
Hi, I have just finished fiting a rev counter to my Transit looking at your clock plugs it looks like the rev counter should run the wires are there, if it dosn't work run a feed from the alternators right hand pin the wire should be white with a black stripe conect the other end to the large conector at the back of the clocks, terminal 8 this also has a white/black trace wire, the clocks should now work.
Dave
Dave12590
Postby bez » Sat Jul 11, 2009 3:52 pm
Dave12590 wrote:Hi, I have just finished fiting a rev counter to my Transit looking at your clock plugs it looks like the rev counter should run the wires are there, if it dosn't work run a feed from the alternators right hand pin the wire should be white with a black stripe conect the other end to the large conector at the back of the clocks, terminal 8 this also has a white/black trace wire, the clocks should now work.
Dave
did all that back on page 1. the clocks do work they just read wrong
bez
Cosworth Powered
Cosworth Powered
Postby Dave12590 » Sat Jul 11, 2009 5:13 pm
Hi,
remove the front, take out the rev counter4 torx screws grrr when you pull the rev counter out there is a calibrating screw on the pcb adjust to suit. I set mine to 750 at tickover it seems about right.
Dave12590
Postby bez » Sun Jul 12, 2009 11:58 am
i dont think ajusting that will make mine work thats just if rev counters not reading bang on,mines reading 5000 rmp on tick over.lol
bez
Cosworth Powered
Cosworth Powered
