How to remove the rear floor panel mk5 swb
Re: How to remove the rear floor panel mk5 swb
Postby AlanN » Wed Mar 27, 2013 11:25 pm
Grinder sounds right to me...
Seeings as you've got a new panel, this is how id probably do it, depends how long my patience last :lol:
I'd mark the chassis with marker pen on the floor, just roughly, I use air grinder to find welds, but you miss some :roll: cut rest of floor out with fine cutter disks, leaving a band over welds, I do this as its easier to lift a 1" or so strip of metal than 4 or 5" or a big section
you must be getting a feel for it by now, the point when you break through the 1st layer, press too hard you don't feel the change. Scraper chisel to lift metal up, popping them as you go (sometimes big hammer :lol: :oops: )
You think thats bad, weve been working on a soft top Sunbeam, thousands of spots, spots, spots, bl**dy spots :twisted:
Postby vanmanloki » Thu Mar 28, 2013 10:58 pm
AlanN wrote:Grinder sounds right to me...
i have defo reached the point of using a grinder to cut the floor out, only i hadn't thought of doing it so neatly. But i like your idea of marking the floor out and cutting it. Leaving just the thin strips will defo make things easier and speed things up.
getting a feel for the spot weld wasn't bad, the ones i was able to find popped fairly easy for the most part, and i used a hammer and chisel for the ones i had drilled off centre or what have you. But the ones i couldn't find were the nightmare. but cutting the floor out i think will defo sort the problem Thanks :D
Ben is coming to weld the floor in on Saturday, so i have to get the floor out tomorrow, and get the frame cleaned painted and under coated ready to go for Saturday morning. i'll take lots of pics of it all and post them tomorrow and Saturday 8)
FORD BUILT TOUGH
1998 Tourneo GLX restoration
viewtopic.php?f=27&t=122620
How to remove a rear floor panel swb mk5
viewtopic.php?f=4&t=127587
vanmanloki
Postby stalwart » Fri Mar 29, 2013 12:04 am
Would be very interested to see how that new floor go's in like the old one :wink:
stalwart
Postby vanmanloki » Fri Mar 29, 2013 12:22 am
i don't think putting in the new floor will be all that difficult, as long as all the bits of the old one is totally removed and cleaned ready for welding. but we'll know for sure on Saturday :roll:
FORD BUILT TOUGH
vanmanloki
Postby vanmanloki » Fri Mar 29, 2013 9:55 pm
i was only able to get one pic today and it wasn't a very good one, my camera on my phone was acting up, but here it is :?
this pic was taken early in the day, by later on i had most of the floor out, but still have few more bits to take off as well as clean everything up
FORD BUILT TOUGH
vanmanloki
Postby vanmanloki » Sat Mar 30, 2013 11:32 pm
we worked on the van for 13hrs today, and the floor is in. just need a bit more welding, some sealing and undercoating.
i got lots of pics but i'll have to put them on tomorrow, i'm beat :(
FORD BUILT TOUGH
vanmanloki
Postby dieselhead123 » Sun Mar 31, 2013 11:08 am
Well done there mate.
Glad it all went well,
Postby AlanN » Sun Mar 31, 2013 11:34 am
You know it will be worth it, no patches on the floor and all the surprises sorted 8)
Postby vanmanloki » Sun Mar 31, 2013 8:11 pm
FORD BUILT TOUGH
vanmanloki
Postby vanmanloki » Sun Mar 31, 2013 8:22 pm
FORD BUILT TOUGH
vanmanloki
Postby vanmanloki » Sun Mar 31, 2013 8:57 pm
dieselhead123 wrote:Well done there mate.
Thanks Tim, it didn't go too bad at all, i think we had more problems with the welder, then we had putting the floor in. but i would say the key to getting the floor in problem free is to get rid of all the old floor cause its a good fit but a snug one :)
FORD BUILT TOUGH
vanmanloki
Postby vanmanloki » Sun Mar 31, 2013 9:04 pm
AlanN wrote:You know it will be worth it, no patches on the floor and all the surprises sorted 8)
it was hard work getting the old floor out, but it was defo worth it, all surprises now sorted no more holes or rotted chassis :D
FORD BUILT TOUGH
vanmanloki
Postby vanmanloki » Sun Mar 31, 2013 9:50 pm
we still have some welding to do tomorrow to finish it off but its almost done.
we just have to drill some holes down the rails, and along the seem, so we can pool weld it, I've already started on the seem as you can see in one of the pics :)
FORD BUILT TOUGH
vanmanloki
Postby vanmanloki » Sun Mar 31, 2013 11:30 pm
the big question now is....do i paint the whole floor including the galvanised part ? :? :? :?
FORD BUILT TOUGH
vanmanloki
Postby Mr RVM » Mon Apr 01, 2013 12:10 am
Yes of course you do :!: :)
Mr RVM
