Prepping for Euro trip
Re: Prepping for Euro trip
Postby ColinJack » Wed Oct 30, 2013 9:32 pm
Make sure you pack a tow rope and stick a nice big UK sticker on the back in case you need a tow. :wink:
Don't need a UK sticker if you have a GB number plate ;)
1989 Mk3 Reimo Camper
1980 Mk2 Holdsworth Camper
ColinJack
Postby ColinJack » Wed Oct 30, 2013 9:47 pm
Kedishen wrote:Just completed a 1 year trip in France, Spain and Portugal.
Preparation
Exhaust is in good shape
Brakes (blow out the drums whilst its off)
Top up all oils etc
Gearbox + axle fluid
Oil and filter change
Cambelt if it needs doing + waterpump and tensioner
Get the tracking done
Clean all electrical grounds in engine bay
Check your spare and lowering mechanism
Get a full set of keys cut and hidden somewhere on chassis
Don't forget to tart up the arches. Only British Transits rust!
Spares
Top up oil for engine, PAS, brakes.
Spare PAS and fan belt
Fuel filter
Shoes and pads
Spare wheel bearing (& drift bar) + split pins
Spare bottom ball joint
Spare tie rod end
Spare locks and ignition barrel
Length of hose to syphon fuel
Tyre repair kit (rubber bung thing)
Several tubes of tyrefix spray stuff
Fuses
Bulbs
Windscreen wiper
Spare ignition switch
Tools
Haynes manual
Trolley jack & wood
Decent socket set
Torque wrench (make sure you got downsizing pieces to fit sockets)
Torx set
Ring Spanners - 8, 10, 12, 13, 15, 17, 18, 32
2x adjustble spanner (large and small)
Pliers
Long nose pliers
Magnet on a stick
Rubber mallet
Rounded hammer
Vice grips
Piece of hollow tube for leverage bar
WD40
High melting point grease
Touchup paint
Cable ties
Jubilee clips
Exhaust u-clamps
Elastic straps
Rachett straps
2x Phillips screwdrivers (large + small)
2x flathead (as above)
Multi screwdriver
Stubby multi screwdriver
3 legged puller
Stanley knife
Pump
Jump leads
Tow rope (it is illegal to tow in Spain)
Good length of strong thin cable (useful for fixing handbrake + throttle cables)
Other odds and ends
Superglue
Clear silicone
Self tapping screws + nuts and bolts or common sizes
Stuff required by law
Bulb Set
GB Sticker if not on plate (a spare is useful)
Headlight deflectors (tape is illegal in Spain)
Reflective jacket for all people in vehicle
Warning triangle (2x if in spain)
You do NOT need a breath test kit, but take one anyway to appease cops
Not going to have room for people at this rate. :)
ColinJack
Postby limitedblack » Wed Oct 30, 2013 10:27 pm
Just tow another transit behind you.
Happy Easter
limitedblack
Postby ColinJack » Wed Oct 30, 2013 10:28 pm
limitedblack wrote:Just tow another transit behind you.
Maybe a trailer with spare engine, gearbox, drive train etc? :lol:
ColinJack
Postby Kedishen » Thu Oct 31, 2013 2:28 am
ColinJack wrote:Not going to have room for people at this rate. :)
its a fine art spreading it around without GF noticing.
Since theres still space, don't forget a voltmeter for when your alternator gets mad. AH! and a hack saw!
Livin' in me van in Portugal.
'93 Mk4 TD 150L Hitop Custom Camper
100ps Epic blue spot
Kedishen
