Rickbu wrote:Hi Andy,yes I made a mistake in saying the low pressure is on the outside of the shaft and should have said inside.also when I said vane pump I did mean the inlet as the outlet simply pressurises the pump body, when I said it goes to the vane Pump I just assumed this to be obvious as like you say it would be pointless otherwise. Now with the high pressure of the pump body on the outside of the governor sleeve and the low pressure ( possibly even a vacuum depending on situation) of the inlet of the vane pump on the inside it means that the force will be constantly trying to close the sleeve down. ( the sleeve closing down increases fuelling so not sure how you come to the conclusion of the reverse effect) Which will increase fuelling. Where as the weights flung out by rpm are pushing the sleeve up ( the shaft) trying to decrease fuelling this also means that if the inlet of the pump starts to see a vacuum due to a blocked filter or higher demand the effect will be even greater as the body pressure will be higher in relation to the inlet pressure thus increasing the effect.you'll see that although I made a mistake between inside and outside the effect I describe is still the same. it's been a while since I looked at this problem but I say again I believe the feed to the governor shaft to be important and why wouldn't you bore it now while you have the chance. I wish I had
Rickbu wrote: tbh it's good to chat about pumps with someone, it's very rare I find others who know anything about them, most avoid even adjusting them,
