AndyG wrote:Ok, I'd finally had enough of this clutch (no wonder I went auto
) It just doesn't travel enough to open/release the clutch plate
I had a brand new clutch fitted some years ago, along with a new ratchet mech. assy. and cable
It was ok to start with but as with all these things, it was only a matter of time before the problem was back
I've tried to find out what actually controls how far back the fork goes, but no success
Anybody
I couldn't see a stop for it, so I guess it "floats"
On a manual adjust cable, it would indeed be the cable that stops it travelling back too far
So it was either make my own adjuster that would stop excessive movement of the fork (a bit like what's used on the FWD BMC cars of the 60's
) or gain more travel on the cable, without cutting a hole out in the floor
So I removed the pedal all together, just to check it isn't a worn auto adjuster and no, it's perfect, with all the genuine Ford numbers on it etc....
Next thing to check was the cable, no visible problems with that
So how could I gain just that little bit of extra travel required
Increase the circumference of the ratchet mechanism
I was first thinking along the lines of screwing a slotted bolt into the mech. where the cable rolls over, that would give more "lift" on the cable as you push the pedal, but this idea was soon scrapped
So using a bit of foam filled satellite cable (half of a twin core) was just the right size to slot in where I wanted, hence increase the circumference of the mech
Refitted and BINGO
I can now actually select gears with engine on
I still can't believe how easy it was to do
(It didn't help, the fact that the so called mechanic didn't bother refitting the rear spring that holds the pedal up
As where this was, it was interfering with the "resting" position of the pedal, which couldn't have helped, but we are talking a possible mm
Here's what I'm on about
SORTED !
