another smoking transit
Re: another smoking transit
Postby trans9 » Sun Jun 01, 2008 8:33 pm
Or if your brave get an air hacksaw and cut the bottom off the rod
You must explain abit this cutting case, there are bolts or what :?: :oops: :oops: :wink:
If it smokes, it works. But why.... :twisted:
trans9
Postby MrMPuk » Sun Jun 01, 2008 9:43 pm
trans9 wrote:Or if your brave get an air hacksaw and cut the bottom off the rod
As he has already said, it's bent to badly to go up the cyclinder!
Postby Guy88 » Sun Jun 01, 2008 9:46 pm
cut the big end off :wink:
2005 Ford F250 Super Duty
1992 MK3 ambulance
1980 A Series crew cab
1984 A series RB44
LIVIN' LOUD
Guy88
Postby trans9 » Sun Jun 01, 2008 9:49 pm
Still, why the hacksaw, MrMPuk, as you must know, there is no need for saw to strip this kind of engine, eventhoug, if it is bended or blasted or not, allenkeys or sockets is enough :twisted:
trans9
Postby Guy88 » Sun Jun 01, 2008 9:52 pm
the rod is too bent to fit up the bore
I.e the main is fouling the sides of the bore and there is not enough movment to move it without damaging the bore
1992 MK3 ambulance
1984 A series RB44
LIVIN' LOUD
Guy88
Postby MrMPuk » Sun Jun 01, 2008 9:54 pm
How would you get it out then when it's to bent to fit up the bore? Other than as Guy says drop the whole bottom end out.
Postby trans9 » Sun Jun 01, 2008 10:00 pm
Guy88 wrote:the rod is too bent to fit up the bore
There is enough room to take it out from underneath the cyl./bore?
You can connect/disconnect piston and con rod when piston is in cylinder, underneath the block.
Sorry my thoughts are faster than my fingers...:)
trans9
Postby Guy88 » Sun Jun 01, 2008 10:03 pm
How do you disconnect the piston fromthe rod without removing it
You can get it out the bottom but the crank has to come out to do it
1992 MK3 ambulance
1984 A series RB44
LIVIN' LOUD
Guy88
Postby MrMPuk » Sun Jun 01, 2008 10:05 pm
:roll:
Postby trans9 » Sun Jun 01, 2008 10:11 pm
You split the conrod lover part and turn the crank abit, then pulling piston lover and removing stopper thing from piston pin, push pin out and conrod is in yours driveway, done it, in 4CA engine. sorry if there is no help. :|
trans9
Postby trans9 » Thu Jun 05, 2008 10:11 pm
thrud wrote:next problem.... the con rod is bent so badly it won't slide up the bore :oops: :cry:
now how do i get the bugger out :?: :?:
Is that bugger out yet, or did I miss something.
trans9
Postby AndyG » Thu Jun 05, 2008 10:54 pm
What trans9 is trying to say, is you may well be able to lower the piston down to the crankshaft, exposing the gudgeon pin, enough for removal/dismantling :!:
It appears he's done this in the past, to one of his engines :!: :D :wink:
Whether this is possible with a badly bent con. rod, is another matter :!:
Postby Guy88 » Thu Jun 05, 2008 10:56 pm
Andyg wrote:What trans9 is trying to say, is you may well be able to lower the piston down to the crankshaft, exposing the gudgeon pin, enough for removal/dismantling :!:
be easier to drop the crank TBH,
If you go this far theres no point in not doing the rings and bearings
1992 MK3 ambulance
1984 A series RB44
LIVIN' LOUD
Guy88
Postby AndyG » Thu Jun 05, 2008 11:07 pm
So everybody did understand what he was saying :?: :roll: :lol:
Wouldn't that also mean the prop, box, flywheel, etc....... has to also come out :?:
:idea: May as well take the engine out and put in a nice TURBO engine in it's place :!: vrooooom :!: :D
Postby trans9 » Thu Jun 05, 2008 11:13 pm
Did some body SAY TURBO, of course new turboengine is the best solution, I wont argue, BUT........ :roll:
Thanks to Andyg for translation...... :wink:
trans9
