Mondeo Dash ...again.
Postby MarkM » Tue Mar 21, 2006 9:09 pm
Andyg wrote:STOP :!: Good news :D I've just checked mine under the bonnet and guess what :?: Same alternator :o Mine already has a rev counter :D . On the side of the alternator there's 2 wires. The bottom one is the WHITE/BLACK cable that is already there. Sorry I can't do photos :( . Have you got a white/black cable on your 16 pin connector :?: Pin 8 :?:
I might have those wires but until I pull the old cluster I won't know...this was why I made this thread to have the info before I did anything....looks like I may have to pull the cluster afterall to see...a*se! feck! feck! feck!
Mondeo cluster sale now on hold :x
MarkM
Postby MrMPuk » Tue Mar 21, 2006 9:10 pm
Removing the cluster isn't to bad and if you take the steering wheel off it's a doddle!
Postby 100ps_drw_hicube » Tue Mar 21, 2006 9:12 pm
MrMPuk wrote:Removing the cluster isn't to bad and if you take the steering wheel off it's a doddle!
tis the only way aint it??? oh and the steering wheel nut is 24mm just to help you out a bit more :lol:
100ps_drw_hicube
Transit Abuser!!
Postby MrMPuk » Tue Mar 21, 2006 9:14 pm
No, I managed without as I couldn't get the wheel off to start with. When I took it out the second time I went and got my wheel puller from storage.
Postby AndyG » Tue Mar 21, 2006 9:15 pm
Do it without taking the steering wheel off. You don't want the airbag to go off :shock: A posi drive and a torx is all thats needed :wink:
Postby 100ps_drw_hicube » Tue Mar 21, 2006 9:17 pm
how do you peeps get the speedo trim past the wheel or do ihave some unusually large wheel as its impossible to fit :? oh and mine aint got a airbag thank f**k they do more harm than good same as seatbelts
100ps_drw_hicube
Transit Abuser!!
Postby MarkM » Tue Mar 21, 2006 9:24 pm
I didn't know that was the size but I just use the 4 leg wheel nut spider trying each one until I get the right size ;)
I had the steering wheel off when I first got the van to swap over the wheels but didn't like the one I put on so went back to the one that came with the van.
I know the older Transit it could be done with the steering wheel still on but you still had to remove the column surround and to be really sure the multiplugs from the switches and still it was tight. I have new switches to fit too when I do all this swapping over so the cab is going to look very clean but getting it all together first and then clearing my day to ensure I have enough time.
MarkM
Postby MarkM » Tue Mar 21, 2006 9:25 pm
Andyg wrote:Do it without taking the steering wheel off. You don't want the airbag to go off :shock: A posi drive and a torx is all thats needed :wink:
No airbag fitted on mine.
MarkM
Postby AndyG » Tue Mar 21, 2006 9:25 pm
From memory you ease the top lip over the steering wheel using a bit of flexing. take your time and more importantly remember it goes back the same way. I take it your stalks are hanging down already :?: Hope this helps.Andy
Postby MrMPuk » Tue Mar 21, 2006 9:27 pm
Never needed to take the stalks off.
Postby MarkM » Tue Mar 21, 2006 9:29 pm
MrMPuk wrote:Never needed to take the stalks off.
Not the stalks just the connectors on the back it allows that little extra bit of clearence and if you happen to jerk the surround you don't break anything, plastic may be a thing of beauty for ever but it can snap and deform.
MarkM
Postby AndyG » Tue Mar 21, 2006 9:42 pm
Just something I've Noticed :idea: You can tell from the front of the binacle if it's an electronic or cable speedo. The trip reset is on the left of the clock for cable speedos and on the right for electronic :!: :D :wink:
Postby MarkM » Tue Mar 21, 2006 9:48 pm
Andyg wrote:Just something I've Noticed :idea: You can tell from the front of the binacle if it's an electronic or cable speedo. The trip reset is on the left of the clock for cable speedos and on the right for electronic :!: :D :wink:
Well if this can be confirmed by another user who got the wrong cluster (at least two on here) then this thread has succeeded in getting at least another two more pieces of the puzzle fixed.
MarkM
Postby 100ps_drw_hicube » Tue Mar 21, 2006 9:53 pm
oh a bit more useless info here the part no's on my speedo unit are from a mondie 8) but the little slides that cover the instrumentation bulbs are from a transit so it seems ford have used bits of both to make the rev counter version for a tranny :?
100ps_drw_hicube
Transit Abuser!!
Postby MarkM » Tue Mar 21, 2006 9:58 pm
100ps_drw_hicube wrote:oh a bit more useless info here the part no's on my speedo unit are from a mondie 8) but the little slides that cover the instrumentation bulbs are from a transit so it seems ford have used bits of both to make the rev counter version for a tranny :?
Just humour me...what are the printed numbers on the circuit plastic on yours?
MarkM
