by rover » Sun Apr 16, 2006 10:51 am
What I find best with an older pinto is to take a screwdriver and a 13mm spanner out on the road with you, just turn the mixture adjust screw out half a turn at a time and then advance the dizzy round by a few mm, drive it and see where you are at, if you are not happy then go a little further with each one.
Just bare in mind that when you are done you wont know wether you are within the M.O.T emmissions regs, but you can always take it to an M.O.T station and get them to put it on the emmissions tester while you set it up, you want to be as close to the 3.5% limit as you can to get the most out of it, mine was at 3.47% on the test.
Rover.
