john.E wrote:just picked her up today and im very happy with her,grand and tight good brakes plenty of poke anyone i showed it to today said it was in great shape even my very critical cousin!just a few things though ,had her cruising at 60 most of the way home and it was at very high revs and felt it could do with another gear im assuming this is normal?but could the ratio in the diff be changed,i know it was suggested somewhere else in the forum that you could just replace the whole axle and is there any mt75 boxes with 6 speed?im not being fussy but just like to know my options!i also read in the owners manual that the diesel tank capacity is only 68 litres.ill try and get some photos up when i can
john.E wrote:thanks andy,3 boxes down four boxes across is "L" and fifth across is "J"
heres the whole thing
EEB7AS 150S
4EC 73.6 4000
W8 2 I L J 0303
B 1CA8 ZA D
R 2835 L B
shor tell me what you can about
Andyg wrote:But having a middle ratio axle is quite normal and as your van is quite a late one like mine, maybe they skimped on the sound insulation as well and that's what the problem is.
Do you have a rev counter on yours
Nearly forgot. An SVO= Special Vehicle Option
john.E wrote:that after market rev counter sounds good alrite and 3000 revs isnt bad at all i thought it was higher,thanks for all the info andy
100ps_drw_hicube wrote:john.E wrote:that after market rev counter sounds good alrite and 3000 revs isnt bad at all i thought it was higher,thanks for all the info andy
turbo di's usually redline around 4100rpm
john.E wrote:Andyg wrote:100ps_drw_hicube wrote:john.E wrote:We're talking when the economy starts to dissapear![]()
yeh i know what you meant ,i was sayin that when its up at 60 or so it sounds like its reving higher than 3000 like!
