Poor starter
Re: Poor starter
Postby MIXA » Sun Jan 10, 2010 1:23 am
As psv said cheap parts meg labour bill ,dont agree with psv about to many lights looks great like the sidemarkers in the steps. is lightbar a one off, is there a thread on the build? aint found it yet if there is
MIXA
Re: Poor starter
Postby johnsgti » Sun Jan 10, 2010 11:22 am
psv-hgv-flt wrote:have you checked fuel tank valve.??
:? No i havent, take it its in the tank/sender. Whats it look like? Is it testable? Thanks
Ford Transit mk5, 2000 W reg, 2.5di.
johnsgti
Re: Poor starter
Postby johnsgti » Sun Jan 10, 2010 3:55 pm
Just been outside having a look at the pump on the van, there does seem to be quite a bit of side to side movement on the leaver were you rev it on top of the pump. Im assuming there should be none.
johnsgti
Re: Poor starter
Postby psv-hgv-flt » Sun Jan 10, 2010 4:42 pm
johnsgti wrote:Just been outside having a look at the pump on the van, there does seem to be quite a bit of side to side movement on the leaver were you rev it on top of the pump. Im assuming there should be none.
no, what miles she done.?? allso check fuel filler cap and this valve on tank. (allways check the small cheap jobs first to save on cost, as it might be that simple. :lol: :lol: :wink: ) but my bet is pump seal.
:wink:
psv-hgv-flt
Re: Poor starter
Postby johnsgti » Sun Jan 10, 2010 4:49 pm
Sorry, not shaw on mileage, engine was a replacement. :( Thanks for pictures.
johnsgti
Re: Poor starter, now new pump
Postby johnsgti » Sat Jan 23, 2010 6:46 pm
:D
johnsgti
Re: Poor starter
Postby johnsgti » Sun Mar 07, 2010 3:11 pm
My mistake with the pump,shouldnt have removed the pulley, should have undone the 4 10m bolts. :oops: Well finally sorted, :D :D :D after putting 4 pumps on and all of them leaking somewhere or an over. :( I picked up the 5th pump, it didnt leak but it was very slow... Really didnt want to remove this pump again, after reading a bit on here about the torque sleeve i stripped it down, and yes it needed cleaning, so off i went for some wire wool and 'Autosol' polish... Refitted and what a difference, its like driving a new van. :D Ran it around for a week to make shaw all ok, have now refitted cam cover and any over clips or fittings as i am happy i wont be removing the front any time soon. :D
So thanks for all your help guys. :D
johnsgti
