Gaz 270 wrote:im no tranny expert but it sounds to me like you have got the crank 180 degrees out , id pull it down leaving your cam and fuel pump pinned and rotate your crank shaft 180 degrees and re build as previous
Altransit wrote:Are you absolutely certain that you used the correct pins in the correct holes for the timing? For example, what size did you use in the flywheel hole and was it the proper pin, or a drill?
There is a second, smaller hole in the flywheel which can set the timing 180 degrees out
bazw wrote:Gaz 270 wrote:im no tranny expert but it sounds to me like you have got the crank 180 degrees out , id pull it down leaving your cam and fuel pump pinned and rotate your crank shaft 180 degrees and re build as previous
apart from the pin not going in to the timing hole ( assuming he got the timing hole and not a balance drilling ) 180 * out i th pistons in the same place as 0*
