trouble starting again
Re: trouble starting again
Postby MIXA » Sat Jan 09, 2010 5:48 pm
Well been called many things but never a troll before ,but love the way peps get wound up on some of these pages one cure is flog it an buy a renault the guy nex door just went to his 1st time since 24 dec still covered in snow it started 1st time , he does have a pair of truck batterys on it though both wired as per single would be and claims never to have had any prob s his old di was the same and that always went 1st or 2nd turn of the key ,mine started straight away again with the blow torch up the pipe but think a second h/d might be in order and reconnect 2nd alternator , used to be for running welding set 110 hookup and jump start from van .
MIXA
Postby sideshow_bill » Sat Jan 09, 2010 6:55 pm
I didn't mean you!
There's too many people willing to post offensive ill informed messages, which makes it hard for those trying to follow a forum in order to gain some relevant information.
Let's try and keep the posts friendly and informative Spell checkers are good too
sideshow_bill
Postby MIXA » Sat Jan 09, 2010 8:56 pm
MY SPELLING IS REALY BAD BUT SPELL CHECKER KEEPS FREEZING MY SCREEN ,i know some peps slag others off at times i just ignore usually, some posts are put on as a laugh, but this does not help as there are some who will just try what is posted with out thinking there is anything wrong with the post to trusting i suppose. But dont like to see posts that if this is done can cause damage or are dangerous to the person doing it, seen pranks in the workshop go wrong and every one there should have known better.
MIXA
Postby dtd4 » Sun Jan 10, 2010 3:59 pm
Easy start should only be used for a couple off seconds when starting. Expect internal damage with excessive use. Such as blown piston rings causing lack of compression. Hence greater use of easy start to get the engine running on a regular basis
dtd4
