toolless wrote:I would like to know how you attach the throttle cable through the cab and which color to color wires do I swap
what would happen if I got a realy old BOSCH pump before they fitted the imobolizer solinoid to it should it still work
the manual peddel bolts on the same, and you may have a rubber bung in the bulkhead at the same place (if not drill it).
find the ign live on the multiplug that go,s in the back of old epic pump for the fuel shut-off.
and yes old type pump is best.
