accelerator pedal
Postby jonnyshag » Sun Aug 20, 2006 3:35 pm
theres a ford part number on it:
97vb - 9f832 - ab
pbt - (gf20 + gb20)
jonnyshag
Postby jonnyshag » Sun Aug 20, 2006 3:38 pm
Andyg wrote:
jonnyshag wrote:ive messed around with the connections just cant get it to work , do you get the complete pedal from fords
:shock: :shock: :shock: Changed their order around :?: what do you mean :?: :!: :shock:
Isn't there two plugs on the older unit :?:
i meant cleaned them up and made sure the wires wernt lose
yes two plugs 1 into the cicarle switch and othe connets to under the dash
jonnyshag
Postby AndyG » Sun Aug 20, 2006 3:43 pm
Doesn't that round bit need to locate correctly so that the internals can swing inside it, back and forth with the pedal action :?:
Postby jonnyshag » Sun Aug 20, 2006 3:44 pm
yes but you can turn it with a scerwdrive
jonnyshag
Postby AndyG » Sun Aug 20, 2006 3:45 pm
If you think you've messed up the colours/order then say so as I can compare to mine :idea: :D
Postby AndyG » Sun Aug 20, 2006 3:46 pm
jonnyshag wrote:yes but you can turn it with a scerwdrive
Fair enough :D Could it have gone on incorrectly :?: or no chance :?:
Postby jonnyshag » Sun Aug 20, 2006 4:07 pm
no ive not changed the courlor i just made sure they were connecting, everything as gone back together as i took it of, this is doing my head , ionly took it off to clean it up :(
jonnyshag
Postby AndyG » Sun Aug 20, 2006 4:15 pm
Well if you've taken it apart once then you can do it again :idea: but before you do have a careful look for a small switch which is activated when the pedal is either full on or in the 'rest' position :idea: it could be this and you should be able to test it with a simple meter :!:
Postby jonnyshag » Sun Aug 20, 2006 4:24 pm
i dont have one of those meters , if i get a piece of wire and just bypass that little switch , would that be an idea?
jonnyshag
Postby AndyG » Sun Aug 20, 2006 4:31 pm
It's an idea, but should it be 'on' or 'off' :?:
:idea: or run a pair of wires so tha you can connect/disconnect them :idea: Not at all happy about this TBH :(
Wish you were down the road :idea: don't want you to blow anything (doubt you could like that though :D
Postby jonnyshag » Sun Aug 20, 2006 4:52 pm
no luck, didnt do nowt
jonnyshag
Postby AndyG » Sun Aug 20, 2006 4:57 pm
Has got to be that round bit :( Did you open it :?: Are the contacts making contact :?:
From the technical diagram there's two contacts and they both work giving opposite value readings back to the ECU, so that tells me if one side packs up the ECU can't work out how much to rev the engine for you :( :(
Postby jonnyshag » Sun Aug 20, 2006 8:42 pm
its a sealed unit but i thought what the hell let see whats in it , theres like little metal contacts inside which pivert round , i knock it out of place and sunot happen and the van reved a little , so it must of gone faulty
jonnyshag
Postby AndyG » Sun Aug 20, 2006 9:12 pm
Sounds like it's packed it's bags :cry:
Off to breakers for you sonny :!: Has to be a '97 :arrow: and any turbo MK5 :wink:
£150 from the stealers :( :roll:
Postby AndyG » Sun Aug 20, 2006 9:13 pm
jonnyshag wrote:its a sealed unit but i thought what the hell let see whats in it , theres like little metal contacts inside which pivert round , i knock it out of place and sunot happen and the van reved a little , so it must of gone faulty
Sounds like you've almost cracked it :o
