F111ORY wrote:Hi, This thread has created a huge amount of interest ( 43 posts ). I know the owner has just serviced the vehicle , but I not but wonder if the fitting if the new exhaust has coincided with the fuel filter becoming blocked or some other fuel related fault .
An awful lot of time is being spent pointing the finger at a sloppy exhaust fitter, when the fault may lie elsewhere. The owner says he put another £20 worth of fuel in. So we can assume he is running around on an empty tank all the time. A sure way to stir up any dirt and block the filter.
Tie a can of fuel under the bonnet somewhere and run 2 pipes direct to the injector pump ( through a £1.50 throw away filter ) and see if you still have the fault!
Regards Rick
Any coincidence theorist would agree Rick, it's a mathematical probability. Even bad vibes affect my motor.
