thermostart retrofit 2.5di 70ps
Re: thermostart retrofit 2.5di 70ps
Postby IgorVigor » Mon Jan 23, 2012 2:00 pm
but you can get ones for other engines for around half that price :shock:
all you need to do is make sure you get the correct thread :)
mind you, is anyone else tempted to fit a thermostart in the exhaust near the back of the van? :lol:
IgorVigor
Postby Backbone of Britain » Mon Jan 23, 2012 2:05 pm
IgorVigor wrote:but you can get ones for other engines for around half that price :shock:
I know mate, I only posted because it's the Ford item and will be the correct thread :) Also has the part number so can be looked up on Fords e-cat and any associated parts may be listed.
2006 Mk6 115 T350 LWB Highroof
2008 Mk7 115 T350 LX LWB Highroof
Backbone of Britain
Postby IgorVigor » Mon Jan 23, 2012 3:47 pm
true :)
I'll probably get a generic thermostart with the correct thread for mine :)
IgorVigor
Postby evilgoat » Tue Jan 24, 2012 2:10 pm
I ordered the linked one. Arrived this morning so I'll tell you if it fits. Would love to do it all tonight but dont have a pipe flaring tool or the correct union, will have to wait till the w/end.
evilgoat
Postby kinty » Tue Jan 24, 2012 7:32 pm
hi all,came across my old mk5 today (the one in these photos),the chap is over the moon with it after having a few ropey mk5s.i asked him whats it start like cold...he said if its real cold he presses the button for 10 secs and its like its been running allready when it fires :D
i told him when i sold it that the van would start in any weather.i just fitted a varta e44 and the old type 2.8kw starter before i sold it..so he can be confident even on the coldest day.still looks a good van.bargain.
i required the van everyday without fail so got prepared to keep it a while..hence the bits and bobs fitted.then a more ideal van came up so he got a bargain :roll:
kinty
Postby evilgoat » Thu Jan 26, 2012 10:10 pm
Well its all here, only IO wont be testing it as I got the wrong size hose to plumb it all in, d'oh!
evilgoat
Postby evilgoat » Sat Jan 28, 2012 11:19 am
Right the linked plug is the right one for mine (2.5di non bannana) Its in, all works BUT in the process of priming everything the engine is now warm enough to start on its own. So will let you know the final results tomorrow. Off to Silverlake scrappy now to get a glowplug relay and some switches to finish it off. Oh and a tyre.
evilgoat
Postby Guy88 » Sat Jan 28, 2012 5:15 pm
MinorMatt wrote:The ford system only kicked in when cranking (as far as I know) and fed out of the fuel filter housing (that blanking bolt on the top)
they use a timer relay to heat the plug, the heater plug has a valve in it that opens when its heated
ford used a feed from the filter, thru a shut off solenoid to the plug, when the engine is cranked the lift pump then provides flow to the filter and the pressure from this pushes fuel to the thermostart 8)
2005 Ford F250 Super Duty
1992 MK3 ambulance
1980 A Series crew cab
1984 A series RB44
LIVIN' LOUD
Guy88
Postby evilgoat » Sat Jan 28, 2012 5:18 pm
All Done
Need to have a think about the glowplug light. Ford switches the +12v and LandRover switches the earth. Will probobly go and order a stand alone light but it all works a charm.
evilgoat
Postby transit-town » Fri Jan 27, 2017 4:28 am
Have a 97 (70ps) that started 1st tip(new battery)after lying idle for 2 years at -1, so how's this so different to this (much needed heating) melarky?????
transit-town
Postby F111ORY » Fri Jan 27, 2017 9:41 am
From my experiences with tractors that use thermostarts, there is two models made. One with a BSP thread and the other with a UNF thread. I also remember that if you remove a few threads off the end of the fuel connection then a female 3/8 brake pipe nut and a couple of inch of brake pipe will give you something that you can connect some fuel line to.
F111ORY
