Just a note of caution for all you wishing to carry out this conversion for yourselves in order to meet the LEZ requirements.
These pinto engines are old and use 'old technology', there are engines out there being sold as 'good' and in most cases, they are not! At Light Commercial Services, we pride ourselves in the quality of workmanship and parts we supply to our customers and our definition of 'good' appears to be significantly different to that of others.
As can be seen in the picture, a 'good' engine that had a badly worn camshaft, this was replaced, a faulty head gasket, the head was removed to find this;
As a precaution, from now on, all the pinto engines we install in customer's vans will be fully stripped and rebuilt.
The engine in the picture will receive a re-bore and have new pistons/rings, new crankshaft bearings as well as full gasket/seal replacement.
Any of you having difficulty sourcing good pinto engines are welcome to contact us regarding supply of these rebuilt units, we have a number awaiting rebuild, but we will no longer be supplying pre-used or second hand engines, although we are happy to install 'customer supplied' units.
We will still be supplying the conversion parts to install these engines into your Transits, including our own power steering pump bracket and the replacement engine mountings to suit the Mk5 chassis.
A pinto will be installed in the surrogate mother over the next few days, pictures will follow, enabling another batch of Mk5 engine mountings to be produced.
