transit mark wrote:On your year of van the heater resistor is in the top of the heater box inside the van not by the headlight. Bit of a mare to get to. Held in with 2 torx screws. On the right hand side.
I removed the piece of black trim that houses the radio to get to mine.
tvman67 wrote:http://fordtransit.org/forum/viewtopic.php?f=31&t=12288..........hope it helps you
alanmercman wrote:hi mines a 1999 swb with a bananna.take the radio out then take the whole front trim off with the ashtray clock and cup holder in it .it pulls off when u remove the screw behind the trim thats around the speedo .the resistor is fixed in the side of fan blower box its got 3 wires to it i think and the fan motors got 2 wires to it .good luck
