Whilst trolling the internet looking for reasons why my engine management light was staying on I came across the following on an Ask a Ford Mechanic site, :-
"They are known issues with the exhaust gas recirculation valve sticking open causing this sort of fault, many different wring problems to engine sensors that are known to give this sort of fault, faults regarding the fuel pump metering valves causing this sort of fault which can not be fixed by changing any parts a later engine management unit software needs to be loaded by a dealer, faults regarding the engine cooling fan will cause this fault and many other known issues".
The EGR valve is clean, so hopefully that can be eliminated as the cause of the problem, I was interested in the comment about the cooling fan as mine has been damaged, it hit a protruding screw and I had to trim the end of the blades as they were ragged.
The EML comes on as normal when the engine is first started and goes out after a few seconds. It will remain off untill the engine has reached operating temp and the revs are allowed to reduce to idle (800RPM). We live in the country so this is usually about 14 Km to the first intersection, when I pull up the light comes on. If I keep the revs above 1000 (foot on throttle and other foot on brake,van has auto transmission) the light will not come on. It does not go into limp mode, it drives quite well, OK acceleration and 120 kmh reached quite easily, only problem seems to be the damn light comes on and occasionally the low coolant light will come on and after a few minutes go out again even though the coolant level is correct.
This is where the comment regarding the fan comes into play, If the damaged fan is not drawing enough air through the radiator at idle but sufficient when revving harder could this cause the light to come on as the engine is running a bit hotter at idle. Sorry if this drags on a bit, I was thinking of turning it into a mini series. All suggestions are welcome. Thank you.
