by puffernutter » Tue Oct 01, 2013 10:20 pm
This is about a transit 2.5DI (in an LDV LWB if it makes any difference). The vehicle is an ex utility vehicle and had twin batteries (just simply paralleled, nothing clever). Also as far as I am aware, the belt is tightened to the correct tension and the alternator is brand new.
When you first start the van there is a squealing noise that comes from the alternator, the volume varies with speed and the tacho needle will only read around 500rpm and doesn't move. The noise seems to come from the alternator, although everything is spinning (as far as I can see). After a while (depends on the load on the alternator I assume) it will quieten down. Worse after it has been left for a while and much worse when the headlights are on. The alternator was replaced as the previous one was making this noise and I assumed it was an alternator on the way out!
I've just fitted a voltmeter and off load (ignition on but nothing else) it reads just over 12v (about what I would expect). After starting it reads just over 13v and gradually creeps up to just over 14v (again what I might expect). The noise seems to stop (on just one observation tonight) when the volts have been over 14 for a while. Certainly experience shows that after starting it makes the noise and it will appear to stop, however if the revs drop for a period (e.g.waiting at traffic lights or a junction) when you start off again the noise will re-appear, but then go after a a shorter time.
As the alternator is new (and it does the same as the one it replaced) I wonder if the problem is the batteries getting old and taking too much charge after starting? As they re-charge the noise goes away. After a period of driving, you can stop and restart without teh noise, leave if for 4 or 5 hours and it reverts to the noise at start up.
The only difference between this alternator and the older one is that the older on would squeal for longer!
Any thoughts or suggestions. I don't really want to shell out on a pair of batteries unless I have to as it wont be cheap and they do start the van OK at the moment! (It is only an occasional use as it what we use to take our Clumber Spaniels and Italian Spinone to dog shows!)
Peter
