tlsjk wrote:yeah 5w-30 Semi Synthetic is what you need for the di, but you will need more than 4.5l
tlsjk wrote:yeah 6 - 6.5l will do it, just remember to allow for the new filter to fill up![]()
best to fill to the full mark (on flat ground), start for about a minute, turn off and leave to settle for 10 - 15 minutes, check and top-up level
also remember to fill the new fuel filter with new diesel or injector cleaner
tlsjk wrote:yeah i would, other than the brake pads, but i would still check them and the rear brakes when doing a service.
also might be worth doing a coolant change, 5l ofhttp://www.eurocarparts.com/ecp/p/car-a ... &0&cc5_866 would do it using a 50/50 mix with water (not needed annually but worth doing if you dont know when it was last done)
tlsjk wrote:also might be worth doing the gear oil
