by axxez » Tue Jan 17, 2023 4:49 pm
Hm... one second.. Maybe I just measured the wrong side... ?
5,5J --> 5,5 x 2,54 = 13,97cm width
rim-material-strength: ca 5mm
my measured offset: 45 -> 4,5cm
offset from different web-pages: 86 -> 8,6cm
13,97 - 4,5 - 0,5 = 8,97cm
--> 8,97 - 8,6 = 3,7mm difference
which COULD mean that I did the right maths, but poor measuring with quiet some tolerance. Only the other side of the rim would be counted. I was measuring in front of the fitted wheel, so I probably did the math for the "offset" on the outer part of the rim.... Offset should be the inner one, not the outer... Is that a correct thought?
