Setting Valves on 2.5Di
Postby PistonMeetValves » Sat Aug 30, 2014 9:54 am
Just wondering if anyone has a step-by-step guide for doing the valves, as I have the new rocker cover gasket for my Banana engine!
Know the settings thread, just new to diesels and this engine - so needing a hand as I only have this weekend to do it and the pickup is currently my daily :oops: :oops: :oops:
Thanks in advance guys, you're awesome 8) 8) 8)
~ PMV
'02 MK6 T280 100 in fetching white/rust ♡
Warren: 'These brakes, they're completely inadequate'
Burt Munro: 'I'm planning on going, not stopping.'
PistonMeetValves
Re: Setting Valves on 2.5Di
Postby Kedishen » Sat Aug 30, 2014 4:19 pm
You will need a socket set and the rocker cover bolts may... be star keys can't remember. Also feeler guages... A torque wrench would be useful, but not essential.
Looking at this picture, you will just have remove the right banana and you can get at the rocker cover. You may also need to disconnect the EGR throttle rod, EGR pipe and support bracket. (in the picture, EGR ROD has alreayd been removed, normally goes from top of fuel pump across top of engine to EGR - EGR is that UFO shaped thing)
(to remove the other side it looks like the injector pipes get in the way..., can't see why it needs to come off anyway)
There is a metal gasket between the bananas so be careful when you split them. There is also a gasket between the manifold and cylinder head. If you are careful you should be able to reuse it. Some gasket paper or some RTV silicone may be good forward thinking.
With the rockers exposed, turn the engine on the crank pulley and follow these settings:
http://www.fordtransit.org/forum/viewtopic.php?t=9565
Heres a picture of where crank pulley is, its the one with socket on.
http://www.ok.eclipse.co.uk/pictures/tr ... AG0336.jpg
When you put the cover back on, follow this diagram for tightening the bolts.
Torque settings are: 6-8 NM or 4-6 lbf ft (hand tight)
When putting the bana inlet manafold back:
Torque settings are: 20-25 NM or 14-18 lbf ft (till it bites, then a TINY bit)
Livin' in me van in Portugal.
'93 Mk4 TD 150L Hitop Custom Camper
100ps Epic blue spot
Kedishen
Postby PistonMeetValves » Sat Aug 30, 2014 7:34 pm
That is ideal man, can't thank you enough! I've just finished doing all of the disassembly by myself, then came in and thought, I hope theres a way to turn it over/ a reply to the thread! :lol: I already assumed behind the plastic cover on crank pulley would be a crank nut anyhows, so i'll try that.
Looking at my rockers, it doesn't look like there is a locking nut...! Just bolty type things, which thread down to the push rod.. Hrrm, will have to see how I get on!
New oil filter (drained it anyways, might as well service it while its parked up!) and rocker gasket ready anyways! My old one looked a little bent, but I think I caught it on the back rocker taking it off. Just made the mating faces as clean as possible between rocker cover gasket and head face as well. I had a bit on a thread how I accidentally bought ZX-1 as well, so i'll chuck that in with the new oil. Was gonna use Castrol GTX 10W40 semi-synth, as that's all I have atm, but will change to lighter oil before winter just to be nice! 8) 8) :lol:
Will update with progress!
EDIT: Meant to ask, when the guide lists the valves as '1' and '6' etc, how do you tell which is which? :oops:
~ PMV
PistonMeetValves
Postby Kedishen » Sat Aug 30, 2014 9:09 pm
Mix ZX-1 at 15%-20% if its the first go. Should also consider putting some in your gearbox and rear axle + your lawn mower, wheel bearings... anything that produces heat and is metal.
That castrol oil is expensive stuff. Leave it in!
For winter, make sure all the connections are good at batteries, starter motor and grounds from starter motor and to behind the drivers headlight.
Kedishen
Postby Kedishen » Sat Aug 30, 2014 9:26 pm
post a pic of your rockers.
Kedishen
Postby Jim Archer » Sat Aug 30, 2014 9:51 pm
Valve No1 at front (ex) valve No8 at rear (in) as per diagram I thought was in the valve timing/setting thread(?)
From front it's ex - in -ex -in etc.
Jim
Mk7 140 Jumbo - Vantunered.
289,000 and counting.
Jim Archer
Postby All4n » Sat Aug 30, 2014 11:00 pm
Nice guide above there 8) set them on mine the other day and it started up like a dream compared to the bag of smokey spluttering spanners it was few days previously!
Be careful when tightening rocker cover bolts up tho if you don't have a torque wrench as they're very each to shear off if not careful!
All4n
Postby MinorMatt » Sun Aug 31, 2014 8:13 pm
Rockers are "stiff bolts" - perfectly normal.
Valve 1 is radiator end, valve 8 is bulkhead end
Lucas Laser 2000 & IDS
95 N Hallmark (white)
96 P 150 TD 100PS LWB Hi-Top
96 P Autosleeper Duetto
2 x 2006 Mk7s
Postby williejbell » Sun Aug 31, 2014 10:05 pm
would the settings on the valves be the same on my 2.5Di which is not the bananna jobby. I think mine need doing cos its quite tappity.
williejbell
Postby AndyG » Sun Aug 31, 2014 10:06 pm
The settings are the same across the range :D
Postby williejbell » Sun Aug 31, 2014 10:16 pm
Thanks for that AndyG I'll get mine done at the first available opportunity. Fitting power steering to the old beastly sweetheart on tues or wednesday might just do it then. Thanks again. williej
williejbell
Postby AndyG » Sun Aug 31, 2014 10:51 pm
Re tap the threads in the engine block (3 from memory) as the build up of rust will make it very difficult trying to get the bolts in for the pump bracket :idea:
Postby PistonMeetValves » Tue Sep 02, 2014 10:16 am
Wow :shock: :shock:
Thanks for all the replies, as I was still uncertain and was needing the pickup for Monday, I just cleaned up the rocker surface really good, noted that the inlet bananers would need cleaned (bout 5mm death dust in em :cry: :shock: ), so I left the valve clearances. Until next time, of course!
Engine fired up really well on the Castrol GTX 10W40, and purred like a kitten once the ZX-1 took effect (although it may be placebo! :oops: )
Driving really well, no leaks.
Will do valves once the missuses car gets back so I don't have to flog the poor pickup as a daily :roll:
Your help and support has been bloody invaluable! :wink: 8) 8) 8)
~ PMV
PistonMeetValves
Postby tibsy » Tue Sep 02, 2014 10:51 am
if/when you do the clearances, make sure you use a tight fitting socket or ring spanner on the adjuster.an open ended spanner can shear the adjuster head off! :roll:
how do i know that!
mk7,60 plate,2.4-115ps-hirf lwb rwd
The words of the Prophet`s are written on the subway walls
tibsy
Postby vanfox » Tue Sep 02, 2014 11:06 am
Do tell....What's ZX-1.
vanfox
