doratheexplorer wrote:DORA HAS BRAKE PROBLEMS FINE ONE MINUTE PEDAL TRAVELS TO FLOOR NEXT MINUTE NO FLUID LOSS SYSTEM FULLY BLED HELP
Easy peasy really ... check out my post viewtopic.php?f=4&t=144761 - definitely worth considering the bigger cylinder but both sizes available cheaply. ColinRestorationvanman wrote:doratheexplorer wrote:DORA HAS BRAKE PROBLEMS FINE ONE MINUTE PEDAL TRAVELS TO FLOOR NEXT MINUTE NO FLUID LOSS SYSTEM FULLY BLED HELP
Definitely sounds as if the master cylinder seals have gone (or flipped) Possibly a rebuild kit required or a complete cylinder (not as £horrific as it sounds)
doratheexplorer wrote:thankyou everyone tried master cylinder repair kit has improved but not eradicated problem mech said it was rusty in there any tips for where to get a replacement thanks again also replaced rear wheel cylinders shoes and knackered rear wheel bearings and fully bled all new fluid front bearings all good
They are all interchangeable between Mk3, Mk4 and Mk5 as far as I am aware. I put a Mk5 one on my 1989 Mk3.Restorationvanman wrote:doratheexplorer wrote:thankyou everyone tried master cylinder repair kit has improved but not eradicated problem mech said it was rusty in there any tips for where to get a replacement thanks again also replaced rear wheel cylinders shoes and knackered rear wheel bearings and fully bled all new fluid front bearings all good
If you can stick a picture up so I can see which one you have I have a few new ones for Mk3's (there were 2 or 3 different types)
Gaz has plenty of 'stock'doratheexplorer wrote:is that cylinder still available
