Electronic / Mechanical Speedometer
Postby toppetsaha » Sat Jan 17, 2015 7:54 pm
Ive been checking the van over & noticed that the speedo coming from the gearbox is electrical, however the inlet on the back of the instrument cluster is for a mechanical cable... Funny how the bloke i bought the van off told me it snapped a while ago.
Im guessing that the gearbox had been changed in the past.
Just wondering if there is any conversion for this? or maybe somebody knows which year van has the electrical instrument cluster & will all of the other connections/plugs will be the same fit as the one that i have currently?
The van is a mk5 1997 2.5Di chassis cab.
MK1 - Camper project
MK6 2.4 75ps
MK7 2.4 100ps
toppetsaha
Re: Electronic / Mechanical Speedometer
Postby Altransit » Sat Jan 17, 2015 8:01 pm
1997 was the changeover year I believe :?
I'm not sure if you can fit the electronic head and make it work, but you can swap the gearbox drive and fit a cable :)
Hopefully, someone can tell us whether both ways is possible :mrgreen: :oops:
Postby toppetsaha » Sat Jan 17, 2015 8:08 pm
Probably a silly question but does the box have to be removed to replace that? :?
Alternative may be to fit an aftermarket speedometer, dont really want to do that though...
MK6 2.4 75ps
MK7 2.4 100ps
toppetsaha
Postby Altransit » Sat Jan 17, 2015 8:10 pm
I've not done it myself, but I'm pretty sure that it's a straight swap out 8)
Postby toppetsaha » Sun Jan 18, 2015 11:27 am
Done a bit of research & it looks like the mech/electric speedo drive units can be swapped over, just got to find one now...
MK6 2.4 75ps
MK7 2.4 100ps
toppetsaha
Postby jay » Sun Jan 18, 2015 12:30 pm
yes the drive just unbolts...if fitting mech drive u need the cable as well
mk1 connect tourneo
jay
Postby toppetsaha » Sun Jan 18, 2015 7:57 pm
Ideal, what do i need the cable for? im assuming you mean the electrical cable.
MK6 2.4 75ps
MK7 2.4 100ps
toppetsaha
Postby paul2012 » Sun Jan 18, 2015 8:08 pm
toppetsaha wrote:Ideal, what do i need the cable for? im assuming you mean the electrical cable.
Speedo drive cable from gearbox to instrument cluster :idea:
2009 Jaguar X-Type 2.0D
IDS & GM GDS2 services
paul2012
Postby toppetsaha » Sun Jan 18, 2015 9:00 pm
Yes already have that :)
MK6 2.4 75ps
MK7 2.4 100ps
toppetsaha
Postby MinorMatt » Mon Jan 19, 2015 5:39 pm
you will need
the mechanical drive pinion (about £15 from ford, and will be the right one for you van)
the cap that goes over it (but you could probably leave the electronic sender in place)
The oil seal (same as a type 9 one)
2 M6 bolts
The cable retaining fork.
If you go to ford, the bits will be about £50, or £5-10 from the scrappy.
You may also need to knock a blank out to allow the pinion to poke through the side of the gearbox and seal to fit. Fitting shouldn't take more than a few minutes. It would also be a good idea to get some MT75 oil (1.25L) and change it while your there (some will leak out, so you will need to top it up anyway)
Postby Bonezy4x4 » Mon Jul 21, 2025 12:40 pm
Im in australia going through this now has anyone got pics please my auto box had cable and electric sensor but the manual box im putting in only has electric sensor hole and on other side has cap where cable could prob go but its smaller hole then where cable came out of on auto box .
Bonezy4x4
