Oil in air filter hose.
Postby soggz » Fri Oct 02, 2015 7:01 am
Hi,i changed me air filter,oil filter,e.t.c,yesterday,but noticed a lot of black oil in the filter hose from the ecu thingy to the air box.Whats causing that?
Mk7 van...still getting used to it...
soggz
Re: Oil in air filter hose.
Postby gotgcoalman » Fri Oct 02, 2015 7:52 am
It's a thing that naturally happens over time.
The oil breather pipe from the rocker cover/filler cap vents any gas/oil vapor back into the intake
manifold.Depending on how "heavy" your engine is breathing it may take weeks,months or longer for
the oil vapor to build up a noticeable anount of oil in the pipe.
You can either,
Clean the pipe regularly.
Fit an oil catch tank.
Remove the breather pipe and blank it at the mainfold end then fit a small K&N type filter to the outlet on the
filler cap allowing the gas/vapor to vent to atmosphere :shock:
I'm assuming the engine is running normally and is regularly given a service.
Too bloody quiet :shock:
gotgcoalman
Postby Mr RVM » Fri Oct 02, 2015 12:32 pm
soggz wrote:Hi,i changed me air filter,oil filter,e.t.c,yesterday,but noticed a lot of black oil in the filter hose from the ecu thingy to the air box.Whats causing that?
If there's a lot of oil then its probably the bolt that that fastens down through the top of the front rocker pedestal to prevent the rocker shaft from sliding out (its a common problem easily sorted) it gets loose and oil (more than normal) gets blown up the filler neck and into the manifold where it then runs back down past the EGR butterfly and into the airfilter box :( remove the rocker cover and tighten the bolt :wink: if you take the oil filler cap off with the engine running you'll notice the amount of oil that gets blown out (if its anything more than a really fine mist then check the above)
Mr RVM
Postby tonybe » Mon Nov 14, 2016 1:22 am
hi tony here just joined not sure how to use the site yet
but dose anyone know how to take out the inlet exhaust manifold out of a 1998 transit the nearest bolt to the front is hitting the fuel pump before it is fully backed out dose this mean i have to take out the fuel pump as well
i want to clean the manifold as it is full of oily muck .
pleas can any one help
tonybe
Postby tonybe » Fri Nov 18, 2016 12:38 am
thanks guis engine is running ok besides but on a hill i loose power a bit and if i excellerating up hill black smoke comes out of the exhaust very bad .
i have blanked off the egr valve and cleaned the injectors but no difference
any ideas would be great Thanks
tonybe
Postby linsey_young » Sat Nov 19, 2016 3:23 pm
I've just cleaned out the top of mine with this problem. Given that it's not got the MOT yet, I haven't run it long enough to see if it has cured the problem but I suspect that it was clogged up oil galleries causing excess pressure under the rocker cover. Can't remember if there was a trick to getting the inlet manifold off of the head since I just split the bananas and cleaned the air filter section and left the cylinder head side attached.
It does seem to run better though.
If I knew then what I know now, I'd have taken it to the scrapyard...
Glad I didn't though :)
linsey_young
