Thinking about blanking the EGR Valve..
Re: Thinking about blanking the EGR Valve..
Postby chaslynch » Wed Apr 06, 2016 6:57 pm
Hi I can say it made a good difference for me
chaslynch
Postby VMH » Mon Apr 25, 2016 12:05 am
Just driven the van myself since locking the butterfly open and it feels much better.
Before it made a strange rattling noise on the over run and at high revs with low throttle opening. This has practically gone.
And it has more torque at low revs. I have a mile long dirt track to my home which was arkward before as first gear was too low and second too high. Now it goes up it in second happily on almost tick over.
It still smokes when i put my foot down though. I will try retarding the fuel pump timing when i get chance.
VMH
Postby VMH » Mon Apr 25, 2016 12:22 am
Oh yea. Did 75 mph on the way home last night. 1995 2.5l LWB high top.
VMH
Postby Snozzleblots » Sat Jul 30, 2016 12:27 pm
Hi all, I have recently purchased an mk5 turbo Di 2.5l transit.
I am concerned wi the fuel economy and power. I would like to try this ger blanking, but I am not sure of a coule of things!
1. Is it ok to do this with a turbo model?
2. Are there other things would I need to do to ensure I do not impact the engine reliability negatively?
Any hints or help would be greatly appreciated.
Cheers.
Graham.
Snozzleblots
Postby southcoaster » Thu Nov 05, 2020 2:31 am
I'm thinking about blanking off my 2.2 mk7 -whats the advantage of disconnecting the butterfly?
southcoaster
Postby Speersy85 » Sun Apr 24, 2022 7:46 am
Hi there engine light now on twice in 1 year egr valve issue both times .
Blanking it and remap the best way to go still??.
Cost?
Speersy85
Postby Altransit » Fri Apr 29, 2022 9:47 pm
This thread is regarding disabling the EGR valve on a Mk5 non turbo engine. The method doesn't apply to the turbo Di engine, and definitely not the later Mk6 & Mk7 engines (or anything after that!)
Postby Almu » Mon May 02, 2022 6:04 pm
Sorry Altransit:
Then the MK5 Turbo Diesel ( Lucas pump ) engines should not put the blanking plate on the EGR , that is , deactivate it ?
Because ?
Thank you
Almu
Postby baba2000 » Tue Jun 21, 2022 12:20 pm
Replaced the Butterfly housing.
baba2000
Postby romie » Sat Apr 15, 2023 7:48 pm
baba2000 wrote:Replaced the Butterfly housing.
That is a nice replacement butterfly housing! Do you have a link from where you got it?
Ta
Ford Transit Tourneo 9 seater minibus 2.5L Di 1999 149k
Citroen Xantia 1.9TD 1996 estate 100% veg 299k
Yamaha YZF-R1 1999 20k
Kawasaki ZXR750 L1 1993 66k (to LPG?)
Suzuki Bandit GSF400 92
Push-bike, Rollerblades, Snowboards, surfboard, longboard and feet
romie
Postby baba2000 » Sat Apr 22, 2023 7:43 pm
I had this made in stainless then shot blasted to take the shine off.
baba2000
Postby baba2000 » Sat Apr 22, 2023 7:45 pm
baba2000
Postby baba2000 » Sat Apr 22, 2023 7:47 pm
Sorry, I just went to a local machine shop and had it made exactly the same dimentions.
baba2000
