rich666 wrote:once you have the intake manifold off what did you use to clean it?
VMH wrote:You don't need to blank it at the exhaust manifold side GDLC. I wouldn't risk snapping the bolts off and causing your self loads of trouble.
I just bought a 1995 model with 150,000 mls which smoked quite badly when i bought it. I have given it a full service, cleaned out the inlet manifold, blanked off the EGR valve and chucked a liter of petrol in the tank in the hope of cleaning the fuel system a bit (it didn't look like it had been looked at for many years)
It still smokes a bit under load though. Is this normal?
I might try locking the butterfly valve open next. See what happens.
