Adding clima to my old MK3 westfalia nugget
Postby bluebit » Fri Mar 11, 2016 10:22 am
Hallo guys,
lately i brought a many parts from newest ford transit (like full front console with all staff inside - heater ect.)
I also brought full clima from this vehicle (ford transit 96).
Generally, clima in transit is really rear, and i spent a lot of time for a search some information about this topic.
But I have some questions.
1) Where i can find engine model ?
My motor look like this (i suspect it isn't original engine from my 91' camper)
May by you know what model it is ?
http://img06.staticclassifieds.com/imag ... dziadz.jpg
http://img1.sprzedajemy.pl/540x405_ford ... 219201.jpg
2) my engine has power steering, so i must repleace old supporting bracket to new one (old can hold on only power steering pump, and new one hold on clima compressor and steering pump ),
I also must replace steering pump pulley - but there is my main problem.
Becouse engine with clima compressor has different belt type.
Now I have one wedge belt (on steering pump and crankshaft).
If I want to mount clima compressor I must replace old crankshaft pulley to other one.
In other way i must change this :
http://flyelectronics.eu/westfalia/stare.jpg
to this :
http://flyelectronics.eu/westfalia/nowe.jpg
but as i know if I have engine from 1991 (or older) my crankshaft pulley has 2.10 deep of tooth,
and newest have 3.10 mm deep of tooth,
Can I replace pulley 2.1 with 3.1 mm (if both will be have the same diameter and number of teeth ) ?
Maybe i have newer engine and this problem don't exist ?
I will be grateful for any suggestions.
bluebit
Re: Adding clima to my old MK3 westfalia nugget
Postby bluebit » Tue Feb 01, 2022 2:21 pm
Hi, there was long time betwen previous post and now. But after that time i made it :)
I add AC to my camper van :)
(5 years ago i change my console to newer one (from Mk5) ) and then i put there evaporator.
In last year i brought some other part and put it into engine chamber.
I made a compresor holder
http://kl.4ppg.eu/transit/1.jpg
http://kl.4ppg.eu/transit/2.jpg
http://kl.4ppg.eu/transit/3.jpg
http://kl.4ppg.eu/transit/4.jpg
http://kl.4ppg.eu/transit/5.jpg
http://kl.4ppg.eu/transit/6.jpg
http://kl.4ppg.eu/transit/7.jpg
http://kl.4ppg.eu/transit/8.jpg
http://kl.4ppg.eu/transit/9.jpg
http://kl.4ppg.eu/transit/10.jpg
bluebit
Postby Peterr » Sun Jul 13, 2025 9:24 am
Unfortunately the photos linked no longer exist. I’m not adding AC but want to add the compressor to make an air compressor and tank for painting. I must have the old bracket which holds only power steering I guess I need to recover a newer bracket that can hold both. Can’t find any photos of how the belt is mounted. Probably my crankshaft pulley isn’t correct either. Anybody with photos?
Keep on Transiting !
Peterr
