What did you do to your mk 3/4/5 today.
Postby angusp » Sun Jun 19, 2016 6:31 pm
Removed front and rear bumpers to have a look underneath.
Bolts fun to remove especially torx ones at front, eventually all out and now replaced with normal ones.
No problems underneath, just a wash and wipe needed thankfully.
Some spray on bumper black and all good.
2000 mk5 100 swb, going.
2005 mk6 350 lwb, not going.
2005 mk6 280 lwb, gone bang.
1996 mk5 190 lwb, gone.
1998 mk5 80 swb, gone.
angusp
Re: What did you do to your mk 3/4/5 today.
Postby vanfox » Mon Jun 20, 2016 10:03 pm
Well, rose from my pit, looked at the weather and decided the cambelt and pump can wait 'till the sun shines, which it did just before teatime.
Found my fan spanner and lo and behold, loosened the fan ready for tomorrow.
vanfox
Postby angusp » Tue Jun 21, 2016 9:20 pm
Talking of cam belts, I had a replacement gates timing belt kit fitted today as wasn't sure when done last.
Cheated though and got local garage to do it - labour charge, 2 hours - happy with that.
Good luck with your changeover van fox.
angusp
Postby po79 » Wed Jun 22, 2016 4:01 pm
Cut out both rear lower quarter panels/wheel arches, inner arches and both sills.
Now I have rust colours bogies.
po79
Postby angusp » Wed Jun 22, 2016 9:44 pm
Sounds like you had a busy day po79!
What you going to weld the new stuff back in with? I fancy getting myself a cheap welder and giving it a go!
angusp
Postby dieselhead123 » Wed Jun 22, 2016 10:40 pm
Fitted a replacement IP;
Image :wink:
Postby angusp » Thu Jun 23, 2016 8:52 pm
Looks very shiny!
Filled a gap a couple of inches long by half inch wide on the inside of my near side front wheel arch with roof sealant!
Bit of a bodge I know, but least it seems to stop water getting in and rusting it from inside out!
angusp
Postby HiRoller » Fri Jun 24, 2016 10:58 pm
Replaced the water pump & cambelt and tensioner.
Replaced alternator on Wednesday just gone along with aux drive belt and adjuster bracket thing...(which snapped).
ImageIMG_4965 by Twiftking, on Flickr
MK5 SWB - Lowered 50mm, PAS fitted, Turbo, Intercooler, 4.11 LSD, 205/65/16 Tyres and Transit MK6 rims.
HiRoller
Postby derv23 » Fri Jun 24, 2016 11:17 pm
You keeping the van after all HiRoller ?
MK5 Tourneo.
derv23
Postby AsteriosN » Sun Jun 26, 2016 7:41 pm
Went on a 200km trip carrying fruits!
AsteriosN
Postby pelmetman » Sun Jun 26, 2016 11:57 pm
Nuffink :( .......
My Fanny is sat on the MIL's drive miles away :? .......I'm starting to miss the expensive cantankerous old cow :roll: .......and the MIL :mrgreen: ......
Fanny a 99 LWB Semi high roof MK 5......Essex V6 auto..... Sold
Horace a 90 SWB Ford Travelhome MK 3....2.5 diesel manual
pelmetman
Postby angusp » Mon Jun 27, 2016 8:24 pm
Pulled up the floor mat & wheel arch cover in the passenger footwell, shone a torch around and pondered where the water was coming in from!
angusp
Postby MinorMatt » Tue Jun 28, 2016 2:57 pm
Welding!
Lucas Laser 2000 & IDS
95 N Hallmark (white)
96 P 150 TD 100PS LWB Hi-Top
96 P Autosleeper Duetto
2 x 2006 Mk7s
Postby CamperVanBeethoven » Fri Jul 01, 2016 8:30 pm
- Unscrewed old, broken, spare wheel hanger. I was amazed when the bolts turned and came off, unseized and unrusted! Only took about 20 minutes to take off and that was because I was taking my time (turn out, turn back in, repeat, a bit at a time...) expecting them to seize on a rusted part of the bolt... Awaiting Mk4 hanger in post now (cheaper than a Mk 5 one). And once fitted I will 'exercise' the hanger every few weeks to make sure it works!
- Refitted the rooftop aerial I fitted months ago. You can probably just about see it in the avatar pic? Well ... I drove under a tree and camped; then the next day reversed out and broke off the aerial :(. Fixing it involved getting one of those 4 section ladders, you know the ones that fold multiple ways, and with 3 sections straight and one bent out at about 110 degrees, it was just perfect height to get to the roof. I tied it to other side of van for safety. I didn't want to cop it like Rod Hull ... :(
- Brushed off some rust from the back bottom while I was down there. Urgh, messy. I need to figure out what I should do to treat the rust ... and then re-underseal it.
- Tidied the van up a bit. It's still a complete state and needs full tidy and clean after Glasto...
CamperVanBeethoven
Postby BROWNYS V6 » Fri Jul 01, 2016 10:38 pm
drove it :mrgreen:
BROWNYS V6
